HP Deskjet 3000 Printers - Blinking Power Light
This document is for HP Deskjet 3320, 3320v, 3322, 3323, 3325, 3420, 3420v, 3425, 3450, 3620, 3645, 3647, 3650, 3651, 3652, 3653, 3658, 3668, 3740, 3743, 3744, 3745, 3745v, 3747, 3748, 3910, 3915, 3918, 3920, 3930, 3930v, 3938, 3940, 3940v Color Inkjet Printers, 3520, 3520v, 3520w, 3535, 3538, 3550, 3550v, 3550w, and 3558 Inkjet Printers.
Blinking Power light
The Power light () might blink (flash) or be off. A blinking Power light indicates that the product requires maintenance, or is in an error state.
Figure : Blinking Power light
Illustration of the product Power light
Your product might look slightly different from the graphics in this document, but the solutions still apply.
The following sections describe the most common issues related to the Power light. Find the issue related to the problem you are experiencing with your product, and then use the solutions provided to resolve the issue.
Issue: The Power light blinks and a message might display on the computer
The Power light blinks, and a message might display on the computer. The following sections describe the most common messages that might display on the computer in combination with a blinking Power light.
How do I resolve this issue? Find the message that displays on your computer (from the following choices), and then expand that section for solutions.
Issue: The Power light blinks when trying to print labels
The product is not picking up labels or paper correctly.
