    Fix HP Printer issue on macOS
HP iPAQ rx5700/5900 Travel Companion Series - High Quality Audio Setup Missing
High Quality Audio setup option is missing from the Connection Wizard screen in HP iPAQ rx5700/5900 Travel Companion series.
Details
The HP iPAQ rx5700/5900 Travel Companion series does not support A2DP profile by design. Due to lack of A2DP profile, the High Quality Audio setup is missing from the Connection Wizard screen.
The HP iPAQ rx5700/5900 Travel Companion series is not compatible with the HP Stereo BT Headphone (HP Part Number: FA303A) as the A2DP profile required is not supported.
