HP Photosmart A620 Series Printers - Installing Print Cartridges
This document contains instructions for installing the print cartridge.
Installing print cartridges
Step one: Install the print cartridge
  1. Remove the HP 110 Tri-color Inkjet cartridge from its packaging.
  2. Pull the pink pull-tab to remove the clear tape from the print cartridge.
    Figure : Removing the tape from the print cartridge
    Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.
  3. Open the output tray. The input tray opens automatically.
  4. Open the print cartridge door.
    Figure : Open print cartridge door
  5. Insert the print cartridge into the print cartridge cradle with the label on top, the copper-colored contacts facing toward the inside of the printer, and the ink nozzles facing down.
    Figure : Insert the print cartridge
  6. Push the print cartridge into the cradle until the cartridge snaps into place.
  7. Close the print cartridge door.
Step two: Load 10 x 15 cm (4 x 6 inch) photo paper
Up to 20 sheets of HP Advanced Photo Paper or 10 sheets of panoramic photo paper can be loaded into the printer in preparation for printing photos.
Use 4 x 12 inch photo paper to print panoramic images.
  1. Place a few sheets of HP Advanced Photo Paper in the input tray with the glossy side facing the front of the printer. A paper sample pack is included in the box with the printer.
  2. Place the paper against the left side of the input tray. Adjust the paper-width guide to fit close to the right edge of the paper without bending it.
    Figure : Inserting paper in the input tray
  3. Once paper has been loaded into the printer touch OK on the touch screen to print an alignment page
Step three: Align the print cartridge
The first time you insert a HP 110 Tri-color Inkjet print cartridge, the printer aligns it automatically. However, if colors in printouts are misaligned, or if the alignment page does not print correctly when you insert a new print cartridge, use the following procedure to align the print cartridge.
Follow the instructions below to print an alignment page:
  1. Verify that 10 x 15 cm (4 x 6) inch paper is loaded in the input tray.
  2. Touch OK and an alignment page should print. If the alignment page does not begin printing follow the steps below.
    1. Touch the Menu icon on the quick touch frame.
    2. Touch Cartridge.
    3. Touch Align Cartridge.
    4. Touch OK. The test page prints.
Figure : HP Photosmart A620 series alignment page
