    Fix Windows 10 Update Issues
HP Indigo Presses - Technical Note 1002: Yours Truly Designer for InDesign® CS2 version 1.1 for Macintosh® and PC
Item
TN Number
1002
Date
22 April 2007
Responsible Engineer
Neta Appel
Revision
00
Revision Description
Original Note
This note supersedes TN-979 Rev 00
System
HP Indigo press 1000, HP Indigo press 1050, e-Print pro+, TurboStream, HP Indigo press s2000, Omnius MultiStream, Platinum, HP Indigo press ws2000, Omnius WebStream, HP Indigo press w3200, HP Indigo press w3250, HP Indigo press ws4000, HP Indigo press ws4050, HP Indigo press ws4500, HP Indigo press 3050, HP Indigo press 3000, UltraStream 2000, HP Indigo press 5000.
Purpose
To announce the release of Yours Truly Designer for InDesign® CS2 version 1.1 for Macintosh® and PC. This version replaces the version 1.0 for the Macintosh® and PC.
Objective
New product.
Background
HP Indigo YTD for InDesign CS2 is an imposition and personalization tool. This version 1.1 offers the following improvements over version 1.0:
  • Multilingual support for English, French, Italian, German, and Spanish.
  • Bug fixes
Purchasing the YTD full functions version authorization code
For upgrades from version 1.0
The authorization codes for version 1.0 are full compatible with version 1.1.
For new installations
  • YTD for InDesign CS2, version 1.1 has two modes:
    • Full functions - Full imposition and personalization options.
    • Light functions - Full imposition options but limited personalization options (limited to 100 records).
  • YTD for InDesign CS2 installs with Full functions for 90 days.
  • After 90 days, the software automatically switches to the Light functions.
  • The Light functions version has no cost and no time limit.
  • The customer may purchase and install a registration code, as a separate option to retain the Full functions by filling in the order form on the MyHPIndigo portal under YTD-ID for Adobe InDesign CS2.
Instructions
  • For Macintosh - Adobe InDesign CS2 for Macintosh PowerPC.
  • For PC - Adobe InDesign CS2 for PC with Windows XP.
Installation
The installation file can be downloaded from My HP Portal or ordered on a CD.
To download from the My HP portal, click: https://h21021.www2.hp.com/C12/C5/HP%20Indigo%20Yours%20Truly%20Designer/default.aspx, then click YTD-ID for Adobe InDesign CS2.
The folder / CD contains the following:
  • Software multilingual installer
  • Multilingual training document
  • Multilingual User Guide
  • Readme document in English
  • Tools:
    • FontConverter
    • DBConverter
    • PPD and more
Part Numbers
Unit Part Numbers
Part Number
CA290-07561
CD including the above contents.
Q4956A
YTD for InDesign CS2, software license for Macintosh. For press installation after Dec 31st 2006
Q4957A
YTD for InDesign CS2, software license for PC. For press installation after Dec 31st 2006
Q4966A
YTD for InDesign CS2, for Macintosh - Software upgrade license. For presses installed before Dec 31st 2006
Q4967A
YTD for InDesign CS2, for PC - Software upgrade license. For presses installed before Dec 31st 2006
Availability
YTD for InDesign CS2, version 1.1 is available immediately:
  • By downloading from the MyHPIndigo portal under YTD-ID for Adobe InDesign CS2
  • By ordering a CD (2 weeks lead time)
Documentation
The complete documentation CD can be accessed from the portal at: http://h21021.www2.hp.com/C19/CD-NEW/Document%20Library/hello-port.pdf.
Notes
None
Feedback
Send to Neta.Appel@hp.com
Technical Note Distribution
HP internal and distributors
Copyright Notice and Disclaimer
© 2007 Copyright Hewlett-Packard Development Company L.P
Reproduction, adaptation, or translation without prior permission is prohibited, except as allowed under the copyright laws.
The information contained herein is subject to change without notice.
The only warranties for HP products and services are set forth in the express warranty statements accompanying such products and services. Nothing herein should be construed as an additional warranty. HP shall not be liable for technical or editorial errors or omissions contained herein.
Published in Israel.
