HP and Compaq Desktop PCs - Error: NVidia Control Application has stopped working
The following error appears when attempting to open nVidia Control Panel:
NVIDIA Control Panel Application <version number> has stopped working
Figure : Error message
This error can occur when a certain version of nVidia software is installed and a certain version of HP My Display software is installed on the same computer.
To correct these errors and access nVidia Control Panel do the following:
  1. Connect to the Internet.
  2. Open HP My Display: click Start, All Programs, HP My Display, and then HP My Display.
  3. Click Help.
  4. Click Update and then Check Update.
    Figure : My Display Update page
    The website called Portrait Displays opens in your Internet browser software.
  5. Complete the required fields, ensure Full version is selected, and then click Submit.
    Figure : Full version selection that appears on the download page
  6. When the software download window opens, click Save to save the file to a location on the hard drive.
  7. When the download is complete, do not open it. Instead, uninstall HP My Display software as follows:
    • In Windows Vista, click Start , Control Panel, Uninstall a program, and double-click HP My Display.
    • In Windows XP, click Start , Control Panel, Add or Remove Programs, and double-click HP My Display.
  8. Follow the instructions in the Windows that open to remove the files.
  9. Restart the computer when done.
  10. Double-click the downloaded file and follow the installation instructions that are presented to install the new version of HP My Display software.
    The latest version of HP My Display software is also available for download from the w2207 software and Driver download pages on HP Customer Care.
