HP 9250C Digital Sender - Network components used for digital-sending
The following table describes the network components used for digital sending.
Component
Network server running Windows® 2000 Professional, Server, or Advanced Server; Windows XP Professional; or Windows Server 2003 Standard or Enterprise Server
The server contains the following components:
  • HP DSS
  • HP MFP DSS Configuration Utility—used to configure and monitor digital-sending features after the HP DSS program has been installed
  • Windows 2000 Fax service—required only when the Windows 2000 Fax service is the method of fax transport
Network
Fast Ethernet 100Base-TX or Ethernet 10Base-T
Digital senders or HP multi-function peripheral (MFP) devices
An HP DSS server can support up to 250 HP 9250C Digital Senders, HP 9200C Digital Senders, or MFP devices on the same network. Each device can be individually configured to support any or all of the digital-sending options.
HP DSS does not support the HP 9100C or 8100C Digital Senders.
Web browser
Users can use a Web browser from any computer on the network to configure and monitor the digital sender by using HP Web Jetadmin, or the digital sender's embedded Web server.
SMTP-enabled e-mail server
This gateway facilitates the e‑mail and Internet fax digital-sending options.
LAN fax server (requires DSS)
A LAN fax server is a network device that centrally handles the sending and receiving of large numbers of fax jobs. HP DSS can be used to configure the digital sender to route outgoing faxes to a LAN fax server.
LDAP server
An LDAP server is a directory server that contains recipients' names and e-mail addresses and supports Lightweight Directory Access Protocol (LDAP). HP DSS uses the LDAP server to obtain addresses for the digital-sender address book.
FTP server
A file transfer protocol (FTP) server can be used as a destination for documents scanned by the digital sender.
Domain controller/Novell directory server (requires DSS)
In order to support user authentication, the digital sender must have access to a domain controller or Novell directory server in order to validate the user's login information.
Network printer (requires DSS)
A network printer can be set up as a destination for documents scanned by the digital sender.
Kerberos Domain Controller
A Kerberos Domain Controller (KDC) provides Kerberos Authentication services on the network. A Windows Domain Controller can be configured to act as a Kerberos Domain Controller.
Novell network support (requires DSS)
If Novell file servers are used on the network, HP DSS can write files into network folders and support network fax folders that reside on Novell servers. The Novell client software must be installed on the network and be configured correctly before Novell-specific attributes can be configured in HP DSS.
