HP CM8060/CM8050 Color MFP with Edgeline Technology - Cancel faxes
You can cancel outgoing faxes that are currently scanning or that are waiting in the job queue. You can also cancel incoming faxes.
Cancel a fax while it is scanning
  1. Press Stop. The Job Status screen opens, and a message appears that confirms the job has been canceled.
  2. Touch OK to continue.
Cancel an outgoing fax
  1. From the Home screen, touch Job Status.
  2. On the Active tab, open the drop-down list named Select Job Type, and select either Outgoing Faxes or Send and Outgoing Faxes.
  3. From the list of jobs, select the job, and then touch Cancel Job.
Cancel an incoming fax
  2. On the Active tab, open the drop-down list named Select Job Type, and select Copy, Print, Incoming Fax Jobs.
