HP Designjet Z3100ps Photo Printer Series - Add a custom paper type
Before you can use a custom paper with your printer you must add a custom paper type and allow the printer to run a color calibration. You can add a custom paper using the HP Color Center in HP Easy Printer Care (Microsoft Windows) or HP Printer Utility (Macintosh OS).
  1. Go to the Color Center in HP Easy Printer Care (Microsoft Windows) or HP Printer Utility (Macintosh OS).
  2. Select Manage Papers.
  3. In Microsoft Windows, select Add new paper.
    In Macintosh OS, click +.
  4. Enter the paper's name.
    It is recommended to use the paper's commercial name to avoid confusion for other users.
  5. Select a paper category.
    The paper category determines the amount of ink used and other basic printing parameters.
  6. Load your custom paper.
    The embedded spectrophotometer is a 45/0 spectrophotometer, as recommended by Graphic Arts International Standards. However, 45/0 geometry is not appropriate to measure color on textured glossy paper. In general, 45/0 spectrophotometers can not accurately measure color on textured glossy paper. For this reason, automatic color calibration is not allowed on HP Collector Satin Canvas.
  7. Click Next. The printer performs a color calibration and prints a calibration chart. This may take ten minutes.
  8. Once the new calibration parameters are calculated and stored, you are reminded to create an ICC profile. Click Done. Your custom paper is added to the paper category you selected.
  9. To create an ICC profile, which allows you to print on your paper with the best possible color accuracy.
