    Fix HP Printer issue on macOS
HP CM8060/CM8050 Color MFP with Edgeline Technology - Default Job Options menu
Use this menu to define the default job options for each function. If the user does not specify the job options when creating the job, the default options are used. To configure default digital-send options (sending to e-mail or a network folder), go to the embedded Web server by typing the network address of the device into a Web browser. For more information, see Use the embedded Web server.
This menu is also available through the embedded Web server. In the embedded Web server, select the Settings tab, and then select Configure Device from the menu on the left side of the screen. See Use the embedded Web server.
The Default Job Options menu has three sub-menus:
  • Default Copy Options (Set the copy options at the control panel only.)
  • Default Fax Options
  • Default Print Options
Values that have an asterisk (*) are the factory-default values. Some menu items have no default.
Default copy options menu
Menu item
Sub-menu item
Values
Copies
Type the number of copies. The factory default setting is 1.
Set the default number of copies for a copy job.
Sides
1-sided original, 1-sided output*
1-sided original, 2-sided output
2-sided original, 1-sided output
2-sided original, 2-sided output
Select the option that indicates the number of printed sides in the original document and for the copies.
Color/Black
Color Mode
Auto detect*
Color
Black
Specify whether copies will be in black or in color.
Color Quality
Professional*
General Office
Staple/Collate
or
Collate
If the HP Multifunction Finisher is not attached, only the Collate option appears.
Staple
None*
Top left
Top left angled
Two left
Three left
Two top
Three top
Set up options for stapling and collating sets of copies.
Some staple options are meant for documents with portrait or landscape orientation, some for only portrait, and some for only landscape.
Portrait
  • None
  • Top left
  • Top left angled
  • Two left
  • Three left
Landscape
  • None
  • Top left
  • Two top
  • Three top
Collate
Off
On*
Reduce/Enlarge
Horizontal Scaling
Automatic*
Type a percent.
If Maintain Proportions is selected, the image is scaled by the same percentage horizontally and vertically. If it is not selected, you can specify the horizontal and vertical scaling percentages individually to stretch or shrink an image more in one direction than the other.
Select Auto include margins to ensure that the entire image appears on the copy, including any content that is close to the edges. If necessary, the device shrinks the image slightly, depending on the size of the printable area on the paper.
Vertical Scaling
Automatic*
Type a percent.
Off
On*
Off*
On
Auto
Off*
On
Paper Selection
Automatic*
Select a tray from the list.
Select the tray that holds the size and type of paper that you want to use for the copies. If you select Automatic, the device uses a tray that contains the same size paper as the original document.
Image Adjustment
Darkness
Automatic*
Adjust the value within the range.
Adjust the Darkness setting to make colors darker or lighter.
Contrast
Automatic*
Adjust the Contrast setting to increase or decrease the difference between the lightest and darkest color on the page.
Background Cleanup
Automatic*
Increase the Background Cleanup setting to remove faint images from the background or to remove a light background color.
Sharpness
Adjust the Sharpness setting to clarify or soften the image.
Content Orientation
Orientation
Portrait*
Landscape
Specify the way the content of the original document is placed on the page.
2-Sided Format
Book-style*
Flip-style
Flip-style original; book-style copy
Book-style original; flip-style copy
If you are making two-sided copies, select the orientation for the back (second) side.
Output Bin
Output Bin <X>
Select the default output bin for copies.
Optimize Text/Picture
Auto detect*
Manually Adjust
Text
Text/Printed Picture
Printed picture
Photograph
Optimize the output for a particular type of content.
Pages per Sheet
One (1)*
Two (2)
Four (4)
Eight (8)
Copy multiple pages onto one sheet of paper.
Page Order
Right, then down*
Down, then right
Add Page Borders
Off*
On
Original Size
Automatically detect*
Select from a list of available sizes.
Describe the page size of the original document.
Watermark
Text
Choose from a list of standard text.
A watermark is a string of text that is printed diagonally across the center of the page.
First Page Only
Off*
On
Type Style
Sans serif
Serif*
Type Size
Small
Medium
Large*
Watermark Color
Choose from a list of colors.
Intensity
Negative Image
Automatic*
Negative image off (normal)*
Negative image on
Use this item to reverse the colors of a scanned image.
Device generated image colors (for example watermarks) are not reversed.
Color Adjustment
Saturation
Adjust from Tranquil to Vivid.
Adjust the saturation and temperature settings to change the overall appearance of color copies.
Temperature
Adjust from Cool to Warm.
One/Two Color
One or Two Color Copy
Off*
One-color
Two-color (One + Black)
Use this feature to convert all the colors in a document to shades of a single color or to shades of a single color plus black. For example, you could convert all colors to varying shades of blue.
Color
Choose a color from the list.
Use this feature to convert all the colors in a document to a single color.
Color Balance
Cyan
The device uses a combination of basic colors to produce all the printed colors. Adjust these colors individually to change the color balance in the copies. For example, increasing the amount of cyan makes copies more blue and less red.
Magenta
Yellow
Black
Overlays
Use first page as overlay
Custom overlay <X>
An Overlay is a semi-transparent image that is printed on each page of a copied document. The overlay can consist of any image, such as a company logo.
Chapter Pages
Pages
Type the numbered pages that the first page of each chapter should begin on.
Use this feature for copying documents that have chapters. You can specify that the chapters always begin on either the left or right page. If necessary, the device inserts blank pages, so that the first page of each chapter is on the correct side.
Position
Right
Left
Numbering
If you select Numbering for the position, each chapter starts on the next available page, but the device is then able to assign chapter-style page numbers using the Stamp Page Number feature.
Stamp Date/Time
Date Format
(No date)*
Select a date format from the list
Use this feature to print the date and time on copies. You can control the numbering style and the position of the information. The date/time stamp is not transparent.
Time Format
(No time)*
4:58 PM
16:58
First Page Only
Off*
On
Type Style
Sans serif
Serif*
Type Size
Select a type size from the list.
Rotation Angle
0 degrees*
90 degrees
180 degrees
-90 degrees
Stamp Position
Select a position from the list. The factory default is On Position 1.
Stamp Position Horizontal Offset
Type a value.
Stamp Position Vertical Offset
Type a value.
Stamp Page Number
Format
P1, P2, P3, …
1,2,3, …
1-1, 1-2, 1-3, …
1/5, 2/5, 3/5, …
-1-, -2-, -3-, ...
Use this feature to print page numbers on copies. You can control the numbering style and the position.
First Page to Stamp
Type a value.
1*
Starting Page Number
Type a value.
1*
Starting Chapter Number
Type a value.
1*
Type Style
Sans serif
Serif*
Type Size
Rotation Angle
0 degrees*
90 degrees
180 degrees
-90 degrees
Stamp Position
Type a value.
Type a value.
Stamp Text
Text
Use this feature to print a predefined text message on the copies or print a message that you specify.
First Page Only
Off*
On
Type Style
Sans serif
Serif*
Type Size
Rotation Angle
0 degrees*
90 degrees
180 degrees
-90 degrees
Stamp Position
Type a value.
Type a value.
Stamp Text Color
Stamp Set Number
Format
0001, 0002, 0003, …
1,2,3, …
0001/1000, 0002/1000, …
1/1000, 2/1000, 3/1000, …
Use this feature to print the set number on copies. For example, if you are making five copies of a document, each page in the first set of copies is stamped with the number 1. The set-number stamp is not transparent.
First Page Only
Off*
On
Starting Set Number
Type a value.
Type Style
Sans serif
Serif*
Type Size
Rotation Angle
0 degrees*
90 degrees
180 degrees
-90 degrees
Stamp Position
Type a value.
Type a value.
Edge-to-Edge
Normal (recommended)*
Edge-to-Edge Output
If the original document is printed close to the edges, use the Edge-to-Edge Output feature to ensure that the maximum amount of content is copied. However, shadows might appear along the edges.
Auto Layout
Auto layout on
Auto layout off*
When the auto layout feature is on, you can place the original document anywhere on the flatbed glass. The device senses the edges of the document and centers the image on the copy.
Auto Crop
Auto crop off
Auto crop on*
Use this feature to remove dark areas from the background when you copy with the flatbed cover open.
Image Justify
Justify Front Side
Select a position from the list. The factory default is Off.
Use this feature to move the image to an edge, a corner, or the center of the page.
Auto Reduce
Off*
On
Justify Back Side
Mirror front side
Off*
On
Erase Edges
Front side erase
Back side erase
All edges
Mirror front side
Use this feature to remove any dark lines that appear at the edges of copies.
Image Shift
Front side shift
Back side shift
Reduce to fit
Mirror front side
Use this feature to shift the image on the page. This feature is similar to Image Justify, but it moves the image by a particular measurement.
Erase Gutter
Erase gutter off*
Erase gutter on
Use this feature to remove the shadows that appear in the center of copies when you copy an open book or when you copy two pages next to each other.
Image Repeat
Image Repeat
Image repeat off*
Image repeat on
Use this feature to copy the same image multiple times on a single sheet of paper.
Cut Lines
On
Off*
Select Cut Lines to print a dashed line between each image so that you can cut them apart.
Automatic Rotation
On
Off*
Select Automatic Rotation to fit the most images possible on a page.
Default Fax Options
Use the following menus to configure default send and receive options for fax jobs.
Fax Send menu
Menu item
Sub-menu item
Sub-menu item
Values
Resolution
Standard (100x200dpi)*
Fine (200x200dpi)
Superfine (300x300dpi)
Use this feature to set the resolution for sent documents. Higher resolution images have more dots per inch (dpi), so they show more detail. Lower resolution images have fewer dots per inch and show less detail, but the file size is smaller.
Image Adjustment
Darkness
Contrast
Background Cleanup
Sharpness
Notification
Notify
None*
This Job
On Error
Use this feature to receive notification about the status of a sent document.
Notification
Print*
E-mail
Original Sides
1 sided*
2 sided
Use this feature to describe the layout for each side of the original document.
Content Orientation
Orientation
Portrait*
Landscape
2-Sided Format
Book-style*
Flip-style
Flip style original; book style output
Book style original; flip style output
Auto Rotate to Match Paper
Off*
On
This setting automatically rotates the scanned image to match the way the paper feeds. Turn this setting off if you do not want to rotate images.
Fax Header
Overlay*
Prepend
Use this option to set how the Fax header appears on the Fax page.
Select Overlay to have the header appear over the Fax content.
Select Prepend to shrink the header and have it appear above the Fax content.
Delayed Send
Delayed Send Off*
Use this item to set a delay for sending a Fax.
Delayed Send On
Time
Time
Original Size
Select from a list of sizes.
Fax Receive menu
Menu item
Sub-menu item
Values
Fax Forwarding
Disabled*
Enabled (type in the fax device phone number)
Use this item to automatically forward an incoming fax to another fax device.
Stamp Received Faxes
Enabled
Disabled*
Use this option to add the date, time, sender’s phone number, and page number to each page of the faxes that this device receives.
Fit to Page
Enabled*
Disabled
Use this feature to shrink faxes that are larger than Letter-size or A4-size so that they can fit onto a Letter-size or A4-size page. If this feature is set to Disabled, faxes larger than Letter or A4 will flow across multiple pages.
Fax Sides
1 to 1 sided
1 to 2 sided
Use this option to control whether faxes are printed on one side or both sides of the paper. To print all incoming faxes on both sides of the paper, select 1 to 2 sided.
Paper Selection
Automatic
Select from the list of trays.
Select the tray that holds the size and type of paper that you want to use for incoming faxes. If you select Automatic, the device uses a tray that has the same size paper as the original document.
Output Bin
Select from the list of output bins.
Select the default output bin to use for faxes.
Stapled jobs always go to Output Bin 5.
Staple
None*
One left
One right
Select the staple option for faxes.
Binding
Normal*
Flipped
Select the binding option for faxes.
Use this menu to set default options for jobs that are sent from a computer.
Print-job settings that you make using the printer driver override settings at the control panel.
Default Print Options menu
Menu item
Sub-menu item
Values
Copies Per Job
Type a value.
Use this feature to set the default number of copies for print jobs.
Default Paper Size
Select from the list of paper sizes.
Use this feature to set the default paper size for print jobs.
Staple/Collate
or
Collate
Staple
None*
One left
One left angled
Two left
Three left
Two top
Three top
One right
One right angled
Two right
Three right
Collate
On*
Off
Output Bin
This item appears only if an optional finisher is installed.
Select the default output bin to use for print jobs.
Print Sides
1 sided
2-sided
Use this feature to select whether print jobs should be single-sided or double-sided by default.
