HP Designjet Z3100ps Photo Printer Series - Change the front-panel display contrast
To change the contrast of the front-panel display, select the (Setup menu) icon, then Front panel options, Select display contrast, and enter a value using the Up or Down key. Press the OK key to set the value.
The default contrast is set to 50.
