HP Color LaserJet CM4730 MFP Series Product - Product walkaround
Front view
1
ADF top cover
2
Automatic document feeder (ADF) input tray for copy/scan/fax originals
3
Control-panel status lights
4
Control-panel display with touch-screen functionality
5
Control-panel keypad
6
Right-side covers (provides access to the print cartridges and other consumables)
7
Tray 2, 3, and 4
8
Paper-level indicators
9
On/Off switch
10
Output bin
11
Scanner lock
Back view
1
Output bin
2
Interface ports
3
On/off switch
4
Power connection
Interface ports
The MFP has five ports for connecting to a computer or a network. The ports are at the left, rear corner of the MFP.
1
Foreign interface harness (FIH)
2
USB 2.0
3
ACC (accessory port uses host USB protocol)
4
Fax connection (for connecting to an optional analog fax accessory)
5
Parallel port
6
EIO interface expansion slot
7
Access port for Kensington lock
8
Network connection (embedded HP Jetdirect print server)
9
AUX port
Serial number and model number location
The model number and serial number are listed on identification labels located on the rear of the printer. The serial number contains information about the country/region of origin, the printer version, production code, and the production number of the printer.
Figure : Sample model and serial number label
Model name
Model number
CB480A
HP Color LaserJet CM4730f MFP
CB481A
HP Color LaserJet CM4730fsk MFP
CB482A
HP Color LaserJet CM4730fm MFP
CB483A
Parallel connection
Establish a parallel connection by connecting the MFP to the computer with a bidirectional parallel cable (IEEE-1284C compliant) that has a c-connector. The cable can be a maximum of 10 meters (30 feet) long.
Figure : Parallel port connection
1
C-connector
2
Parallel port
To use the enhanced capabilities of the bidirectional parallel interface, ensure that the most recent printer driver is installed.
Factory settings support automatic switching between the parallel port and one or more network connections on the MFP.
USB connection
This MFP supports USB 2.0 device and host USB connections. The USB ports are located on the back of the MFP. You must use an A-to-B type USB cable that is no longer than 2 meters (6.56 feet)
Figure : USB connection
1
USB connector
2
USB port
Auxiliary connection
This MFP supports an auxiliary connection for paper handling input devices. The port is located on the back of the MFP.
This connector cannot be used by the 3-bin mailbox or stapler/stacker accessories.
Figure : Auxiliary connection
1
Auxiliary connection port (Jetlink)
Country: Flag Serbia
