    Windows 11 Upgrade Guide
     Connect with HP support faster, manage all of your devices in one place, view warranty information and more. Sign up for an HP account
HP Photosmart C4200 All-in-One Printer Series- Setting up the All-in-One (Hardware)
  • Unpack the All-in-One
  • Connect the power cord and adapter
  • Turn on power
  • Select the language/region
  • Load plain paper
  • Install the cartridges
  • Align the cartridges
Follow these steps in order.
  1. Lower both the paper tray and the cartridge door.
  2. Remove all packing material from theproduct, including the protective film on the product control panel.
    Figure : Remove the packing material and protective film
Step three: Connect the power cord and adapter
  1. Connect the power cord and adapter to the product.
  2. Connect the other end of the power cord to an alternating current (AC) power outlet.
    Figure : Connect the power cord
Step four: Turn on power
Press the On button () on the control panel to turn on the product.
Figure : Turn on the product
Step five: Select the language/region
  1. When the control panel display prompts you, use the buttons to the left of the display to select your language, select OK, and then confirm.
  2. When the control panel display prompts you, use the buttons to the left of the display to select your country/region, select OK, and then confirm.
Step six: Load plain paper
  1. Pull the tray extender out as far as it will go.
  2. Slide the paper-width guide to its outermost position.
    Figure : Slide the paper-width guide
  3. Tap a stack of plain white letter or A4 paper on a flat surface to align the edges, and then check the paperfor the following:
    • Make sure it is free of rips, dust, wrinkles, and curled or bent edges.
    • Make sure all the paper in the stack is the same size and type.
  4. Insert the stack of paper into the input tray with the short edge forward and the printside down. Slide the stack of paper forward until it stops.
    Figure : Load paper
    Make sure that the product is idle and silent when you loadpaper into the input tray. If the product is servicing the print cartridges orotherwise engaged in a task, the paper stop inside the device might not be inplace. You could push the paper too far forward, causing the product toeject blank pages.
  5. Slide the paper-width guide inward until it stops at the edge of the paper.
    Do not overload the input tray; make sure the stack of paper fits within the input trayand is no higher than the top of the paper-width guide.
    Figure : Move paper-width guides inward
  6. Press the button next to OK on the control panel display.
Step seven: Install the cartridges
The product must be on before you can insert the cartridges.
  1. Open the cartridge door.
    Figure : Opening the cartridge door
  2. Make sure the carriage moves to the right. If it does not move to theright, turn the device off, then turn it back on again.
  3. Open the packaging and remove the tape from both cartridges.
    Figure : Removing the tape
    Do not touch the copper-colored contacts orre-tape the cartridges.
  4. Hold the cartridges with the HP logo on top.
  5. Insert tri-color cartridge in the left cartridge slotand the black cartridge in the right cartridge slot.
    Figure : Inserting the cartridges
  6. Push the cartridge firmly into the slot until it snaps intoplace.
  7. Close the cartridge door.
Step eight: Align the cartridges
When a new cartridge is installed, the product aligns the cartridge. Align the cartridges at any other time by using the software installed with the product. Aligning the cartridges ensures high-quality output.
If a cartridge is removed and reinserted, the product willnot prompt for an alignment. The product memory retains thealignment values for that cartridge.
Follow these steps to align newly installed cartridges.
  1. When prompted, make sure that plain, white letter or A4 paper is loaded in the input tray, and thenpress the button next to OK. The alignment page prints.
  2. Lift the lid. Place the top of the alignment page face-down on the front, right corner of the scanner glass.
    Figure : Placing the alignment page
  3. Close the lid.
  4. Press the button next to OK.
    When the On button stops flashing, the alignment is complete and the page can beremoved.
