    Windows 11 Upgrade Guide
HP Deskjet F4100 All-in-One Printers - Blinking Lights
This document is for HP Deskjet F4135, F4140, F4150, F4172, F4175, F4180, F4185, F4188, F4190, and F4194 printers.
The lights on the front of the printer indicate the printer status. These lights can be on, off, or blinking (flashing), depending on the status of the printer. Blinking lights can indicate error conditions. They might also indicate that the printer is starting up, processing a print job, or charging batteries.
The following sections describe the most common issues related to the light patterns on your product. Find the issue related to the blinking lights pattern you are experiencing, and then follow the steps to resolve the issue.
An E might also appear in the Number of Copies display. This is an additional indication that there is an issue with the product that needs to be resolved. The presence of an E, however, does not affect the meaning of the blinking lights, and can be disregarded for troubleshooting purposes.
Service the All-in-One
Service or replace your HP product if the issue persists after completing all the preceding steps.
Go to Contact HP Customer Support to schedule a product repair or replacement. If you are in Asia Pacific, you will be directed to a local service center in your area.
To confirm your warranty status, go to HP Product Warranty Check. Repair fees might apply for out-of-warranty products.
