HP PCs, Printers - HP Update Software is Retired (Windows)
This document is for HP computers with Windows and HP printers.
HP Update, also known as HP Software Update Utility, has been retired and is no longer providing new software updates. When HP Update checks for updates, a No new updates available message displays.
HP recommends uninstalling HP Update with the Uninstall a program feature in Windows.
Example of the HP Update window
Refer to these frequently asked questions for more information about HP Update.
