    Fix HP Printer issue on macOS
Blinking Lights on the HP Deskjet F300 All-in-One Printer Series
The lights on the front of the product indicate the status. These lights can be on, off, or blinking (flashing), depending on the status of the product. The Power light, Paper light, Print Cartridge light, Plain Paper Type, and Photo Paper Type lights can all blink in distinct patterns to indicate the status or error conditions.
Other lights, such as those for the Paper Type and Resize to Fit buttons, indicate a selected user preference only and do not blink.
    Illustration of the control panel with potential blinking lights
  1. Power light
  2. Paper light
  3. Print Cartridge light
  4. Plain Paper Type light
  5. Photo Paper Type light
This document describes the light patterns on your product as blinking or flashing lights. In this document, "flashing" means the same as "blinking."
Blinking lights
The following sections describe the combinations of blinking lights that display on the product control panel. Find the blinking lights pattern you are experiencing, and then follow the steps to resolve the issue.
There might be more than one solution for some blinking lights patterns. After you find the pattern that matches your blinking lights pattern, try each solution to resolve the issue.
Issue: All the lights are off
In this error condition, the following blinking lights pattern displays on the control panel:
  • Power light: Off
  • Paper light: Off
  • Print Cartridge light: Off
  • Plain Paper Type light: Off
  • Photo Paper Type light: Off
Animated gif showing no lights blinking
Issue: Power light blinks fast for 3 seconds, and then turns on
In this error condition, the following control panel blinking lights pattern displays:
  • Power light: Blinks fast for 3 seconds
  • Paper light: Off
Animated gif of the Power light blinking fast for 3 seconds
Issue: The Power light blinks fast for 20 seconds
  • Power light: Blinks fast for 20 seconds, and then turns on
  • Paper light: Off
Animated gif of the Power light blinking fast for 20 seconds
Issue: The Paper light is blinking
  • Power light: On
  • Paper light: Blinking
Animated gif of the Paper light blinking
Issue: The Print Cartridge light is blinking
  • Power light: On
  • Paper light: Off
  • Print Cartridge light: Blinking
In addition to the blinking light, an "E" might appear in the Copies area.
Animated gif of Print Cartridge light blinking
Issue: The Paper and Print Cartridge lights are blinking
  • Power light: On
Animated gif of Paper and Print Cartridge lights blinking
Issue: The Power light, Paper light, and Print Cartridge light are blinking
  • Power light: Blinking
Animated gif of the power, paper, and print cartridge lights blinking
  • Cause
    A fatal error has occurred.
Issue: All the lights are blinking
Image of the control panel with all lights blinking
Service the printer
Service or replace your HP product if the issue persists after completing all the preceding steps.
Go to Contact HP Customer Support to schedule a product repair or replacement. If you are in Asia Pacific, you will be directed to a local service center in your area.
To confirm your warranty status, go to HP Product Warranty Check. Repair fees might apply for out-of-warranty products.
