    Fix HP Printer issue on macOS
Printer Specifications for HP Deskjet D2430, D2445, D2460, and D2468 Printers
Figure : HP Deskjet D2400 series printer
Model numbers
Printer model number
Availability
HP Deskjet D2430
CB614A
US (One cartridge)
HP Deskjet D2460
CB611A
World Wide except China
HP Deskjet D2445
CB613A
US Walmart
HP Deskjet D2468
CB612D
China
Features
  • Borderless printing on supported paper sizes
  • Ink level indicator
  • Button to launch HP Photosmart Express software
  • High-speed Universal Serial Bus (USB)
  • 1000 pages-per-month duty cycle
  • Print Cancel button
Print speed
The print speeds listed in the tables below are approximate (and maximum) speeds using two ink print cartridges. Actual print speeds will vary depending on the system configuration, software program, and document complexity.
Plain paper
Mode
Black or color
Speed (ppm) on plain paper
Fast draft
Black
*up to 20 after first page
Mixed text with color graphics
*up to 14 after first page
*See www.hp.com/go/inkjetprinter for details.
102 x 152 mm (4 x 6 inches) photo paper with white borders
Mode
Speed (seconds) to print one photo
Fast draft
*as fast as 44 after first page
Borderless 102 x 152 mm (4 x 6 inches) photo paper
Mode
Fast draft
* as fast as 49 after first page
Print quality and resolution
Resolution in the tables below is shown in dots per inch (dpi).
Black True Type text resolution
Print mode
Paper type
Resolution
Fast Draft
Plain
300 x 300 dpi
Fast Normal
Plain
600 x 600 dpi
Normal
Plain
600 x 600 dpi
Best
Inkjet
1200 x 1200 dpi
Maximum dpi
Plain
4800 x 1200 dpi optimized
Plain paper printing resolution
Print mode
Paper type
Resolution
Fast Draft
Plain
600 x 300 dpi
Fast Normal
Plain
600 x 600 dpi
Normal
Plain
600 x 600 dpi
Best
Inkjet
1200 x 1200 dpi (Photo REt)
Maximum dpi
Plain
4800 x 1200 optimized (Photo REt)
Photo paper color resolution
Print mode
Paper type
Resolution
Fast Draft
Plain or photo
1200 x 1200 dpi
Fast Normal
Plain or photo
1200 x 1200 dpi
Normal
Plain or photo
1200 x 1200 dpi
Best/PhotoREt
Plain or photo
Maximum dpi
Plain or photo
4800 x 1200 optimized dpi (Photo REt) 1200 x 1200 input dpi
Operating systems - minimum system requirements
Windows 2000 Professional, XP Home, XP Professional, and Vista
Mac OS X v. 10.3.9 and later
Minimum RAM
128 MB
128 MB; 256 recommended
512 MB (for Vista)
Minimum hard disk space available
250 MB
150 MB
Minimum processor
Any Intel® Pentium® II, Celeron®, compatible processor, 233 MHz or higher
G3, G4, G5 or Intel Core processor
800 MHz 32-bit (x86) or 64-bit (x64) processor (for Vista)
Browser
IE 5.01 with Service Pack 2 or later
Any Web browser
Super Video Graphics Array (SVGA) monitor display resolution
800 x 600, 16-bit color
None
Connectivity
Paper handling
Media (paper) weights
Category
Specification
U.S. letter
65 to 90 g/m2 (16 to 24 pounds)
Legal
70 to 90 g/m2 (20 to 24 pounds)
Envelopes
Index cards
up to 200 g/m2 (110 pounds maximum )
Photo paper
up to 280 g/m2 (75 pounds maximum)
In tray and out tray capacity
Paper type
In tray capacity
Out tray capacity
Plain paper
up to 80 sheets
up to 50 sheets (black text)
up to 20 sheets (color)
Envelopes
up to 10 envelopes
up to 10 envelopes
Index cards
up to 20 cards
up to 20 cards
Greeting cards
up to 20 cards
up to 20 cards
Transparencies
up to 20 sheets
up to 20 sheets
Labels (U.S. letter or A4 sheets)
up to 15 sheets
up to 15 sheets
Photo paper
up to 15 sheets
up to 15 sheets
Custom size media
Dimension
Size
Width - minimum and maximum
77 to 216 mm
(3.0 to 8.5 inches)
Length - minimum and maximum
127 to 356 mm
(5.0 to 14.0 inches)
Supported paper and sizes
Paper type
Size
U.S. letter
216 x 279 mm (8.5 x 11 inches)
U.S. legal
216 x 356 mm (8.5 x 14 inches)
Executive
184 x 267 mm (7.25 x 10.5 inches)
A4
210 x 297 mm (8.3 x 11.7 inches)
A5
148 x 210 mm (5.9 x 8.3 inches)
127 x 178 mm (5 x 7 inches)
203 x 254 mm (8 x 10 inches)
Supported envelopes and sizes
Envelope type
Size
Number 10
105 x 241 mm (4.1 x 9.5 inches)
Invitation A2
111 x 146 mm (4.4 x 5.8 inches)
DL
110 x 220 mm (4.3 x 8.7 inches)
C6
114 x 162 mm (4.5 x 6.4 inches
Supported index and greeting cards and sizes
Card type
Size
Index
76 x 127 mm (3 x 5 inches)
127 x 203 mm (5 x 8 inches)
A6
105 x 148.5 mm (4.1 x 5.9 inches)
Supported labels and sizes
Label type
Size
U.S. letter
A4
Supported transparencies and sizes
Transparency type
Size
U.S. letter
A4
Supported photo paper and sizes
Photo paper type
Size
U.S. letter
A4
A6
Photo card with tab (prints with border) 10 x 15 cm
Photo card with tab (prints with border) 10 x 20 cm
102 x 203 mm (4 x 8 inches)
Photo card 13 x 18 cm
130 x 180 cm (5 x 7 inches)
Supported borderless photo paper and sizes
Photo paper type
Size
A6
A5
148 x 210 mm (5.8 x 8.3 inches)
A4
4 x 6 with tab
4 x 8 with tab
5 x 7
8 x 10
8.5 x 11.5
216 x 292 mm (8.5 x 11.5 inches)
Self Adhesive with tab (10 x 16.3 cm)
102 x 163 mm (4 x 6.5 inches)
Photo card with tab (10 x 12 cm)
102 x 120 mm (4 x 4.72 inches)
Photo card with tab (10 x 15 cm)
Panoramic (10 x 20 cm)
102 x 254 mm (4 x 7.87 inches)
Panoramic (10 x 25 cm)
102 x 254 mm (4 x 9.84 inches)
Panoramic (10 x 30 cm)
102 x 305 mm (4 x 12 inches)
Print cartridges
Physical specifications
The dimensions listed are for the printer with the paper tray extended.
Category
Specification
Width
428.19mm (16.86 inches)
Height
142.09mm (5.519 inches)
Depth
192.27mm (7.57 inches)
Net weight (without cartridges and power supply)
2.5 kilograms (5.51 pounds)
Electrical specifications
Region
Input Voltage
Input Frequency
World Wide
100 to 240 volts, alternating current
50 to 60 Hz
India/China
200 to 240 volts, alternating current
50 to 60 Hz
Power consumption
Connection type
Specification
USB, not printing
7watts maximum
USB, while printing
20 watts average
Power save mode
Less than 3 watts
Operating environment
Operating conditions
Maximum operating conditions
Specification
Temperature
50 to 95 degrees F (10 to 35 degrees C)
Humidity
15 to 80 percent relative humidity non-condensing
Operating conditions for best print quality
Optimal operating conditions
Specification
Temperature
59 to 86 degrees F (15 to 30 degrees C)
Humidity
20 to 80 percent relative humidity non-condensing
Noise levels
Declared sound pressure levels (LpA)
Print mode
Sound pressure level (decibels)
Fast Draft
56.0
Fast normal
46
Normal
48.0
Best
38.0
Declared sound power levels (LwAd)
Print mode
Sound power, bels (A)
Fast Draft
6.9
Fast normal
5.9
Normal
6.1
Best
5.2
Duty cycle
1000 pages per month
Region
Printer
Print cartridges
North America
Canada
One year
90 days
End of life or date stamped
Europe
One year
Depends on country*
Asia Pacific
One year
90 days
Latin America
One year
90 days
*Warranties can vary worldwide depending on local legal requirements.
Material Safety Data Sheets
Material Safety Data Sheets (MSDS) can be obtained from the HP Web site at www.hp.com.
