HP CM8060 and CM8050 Color MFP with Edgeline Technology - Overview
Product Description
HP CM8060/CM8050 Color MFP with Edgeline Technology
Product Features
Feature
Models
  • HP CM8060 Multi Function Printer
  • HP CM8050 Multi Function Printer
Control panel
HP Easy Select control panel provides access to all features
Adjustable backlight
Numeric keypad plus five job-control hard keys
Sleep button to put the device into an energy saving Sleep mode
On/off button on the control panel
Paper handling
The standard input trays hold a total of up to 1,580 sheets of 75 g/m2 (20-lb bond) paper.
  • Tray 1 holds up to 80 sheets.
  • Trays 2–4 each hold up to 500 sheets.
The document feeder holds up to 100 sheets of 75 g/m2 (20-lb bond) paper.
The optional high-capacity input tray (Tray 5) holds up to 4,000 sheets of 75 g/m2 (20-lb bond) paper.
The single output bin holds up to 300 sheets of 75 g/m2 (20-lb bond) paper.
The optional finishing device holds a total of up to 3,700 sheets of 75 g/m2 (20-lb bond) paper.
  • Output Bins 1–2 each hold up to 400 sheets.
  • Output Bins 3–4 each hold up to 200 sheets.
  • Output Bin 5 holds up to 2,500 sheets.
Connectivity
Hi-Speed USB 2.0 cable interface
Host-USB
LAN (RJ-45)
Enhanced input/output (EIO) slot for adding an HP Jetdirect print server, a parallel port, or other accessories
Memory
1024 MB of random access memory (RAM), standard. This is also the maximum memory for the device.
80 GB embedded hard disk
Software Overview
Feature
Drivers and fonts
HP PCL 6, HP PCL 5c, HP postscript level 3 emulation, Fax driver, 93 internal fonts
Ooperating systems
Windows 2000, Windows XP (32-bit and 64-bit), Windows Server 2003 (32-bit and 64-bit), Windows Vista (32-bit and 64-bit), Mac OS X v10.2.8, v10.3.9, v10.4 and later
Not all printing features are available from all printer drivers or operating systems.
The fax driver is not currently available for Windows Vista, but it will be available in the future. See the following Web sites for more information: www.hp.com/go/CM8060edgeline_sw or www.hp.com/ go/CM8050edgeline_sw.
