HP Pavilion vp15 Monitor - Product Specifications
This document applies to the HP Pavilion vp15 monitor.
The HP Pavilion vp15 is a 15-inch flat panel monitor with liquid crystal display (LCD) and thin-film transistor (TFT) screen.
Figure : HP Pavilion vp15 LCD flat panel monitor
RF122AA
Features
The HP Pavilion vp15 LCD flat panel monitor has the following features:
  • 1024 x 768 factory-set resolution
  • VGA analog video input supported
  • Plug and Play capability, if supported by your computer system
  • On-screen display (OSD) adjustments for ease of setup and screen optimization
  • Energy Star compliant
Technical specifications
LCD feature
Specification
Display size
15-inch (38.1 cm) diagonal and viewable image
Display type
Thin-Film Transistor LCD active matrix
Anti-glare coating
Input terminal
VGA 15-pin D-type connector
Scanning frequency
Horizontal scan range 24-83 KHz
Vertical scan range 50-76 Hz
Recommended resolution (H x V)
1024 x 768 @ 60 Hz
Color
up to 16 million colors
Contrast ratio
up to 500:1
Response time
8 ms
Pixel pitch
0.297 mm
Power source - AC/DC adapter
Input rating: 100 to 120V~
Power consumption: <31 W in operating mode, <2 W in sleep mode
Operating environment
Temperature: 50 degrees F to 95 degrees F (10 degrees C to 35 degrees C )
Humidity: 20% RH through 80% RH (non-condensing)
Storage environment
Temperature: -4 degrees F to 140 degrees F (-20 degrees C to 60 degrees C)
Humidity: 5% RH through 90% RH
Dimensions
H x W x D, including base:
13.9 x 15.9 x 7.6 inches (35.3 x 40.3 x 19.3 cm)
Unpacked: 6.8 lbs (3.1 Kg)
EMI standard
FCC Class B
Mounting
Standard VESA 4-hole 75 mm x 75 mm
EPA Energy Star
As an Energy Star Partner, Hewlett-Packard has determined that this product meets the Energy Star guidelines for energy efficiency.
