HP Notebook PCs - Steps for Removing and Replacing the Memory
This document provides instructions for the removal and replacement of the memory for the HP510 series notebook PCs.
Use the video as a guide while following the written instructions below.
To view the video press the Play button on the player control bar below the video.
To stop the video press the Pause button on the player control bar below the video.
To restart the video press the Rewind button on the player control bar below the video.
Flash Player from Macromedia is required to view this video. Visit the Macromedia website (in English) to download and install Flash Player.
Step 1 - Remove the battery
  1. Slide both battery release latches toward the inside of the notebook simultaneously to partially eject the battery.
  2. Slide the battery out of the battery bay.
Step 2 - Remove the memory board
  1. Loosen the captive P1 Phillips-head screw that secures the memory/wireless LAN Mini PCI card cover to the bottom of the notebook.
  2. Use your finger or a flat-bladed tool to lift the edge of the memory/wireless LAN Mini PCI card cover and remove it.
  3. Push both arms outward simultaneously to release the memory board to the spring tension position.
    When handling a memory board, use care to prevent touching the memory chips on the board. Touching the memory chips could damage or destroy the memory.
  4. Grasp the memory board by the edges and pull gently to remove it.
  5. Place the memory board in a static dissipative bag.
Step 3 - Replace the memory board
  1. Remove the memory board from the static dissipative bag.
  2. Locate the alignment slot and align it to the empty board receptacle.
  3. Grasp the memory board by the edges and push gently to replace it.
  4. Press the memory board down to latch the arms.
  5. Toe the memory/wireless LAN Mini PCI card cover into the enclosure.
  6. Tighten the captive P1 Phillips-head screw.
Step 4 - Replace the battery
  1. Slide the battery into the battery bay until it is properly seated and the release latches click.
