HP Color LaserJet CP4005 Printer Series - Network Configuration
Certain network parameters need to be configured on the printer. These parameters can be configured from installation software, the printer control panel, the Embedded Web Server, or management software, such as HP Web Jetadmin.
For more information about supported networks and network configuration tools, see the HP Jetdirect Print Server Administrator’s Guide. The guide comes with printers in which HP Jetdirect print server is installed.
This document contains the instructions for configuring TCP/IP network parameters from the printer control panel.
Configuring TCP/IP parameters
Printer control panel can be used to configure the TCP/IP parameters:
  • IP address (4 bytes)
  • Subnet mask (4 bytes)
  • Default gateway (4 bytes)
Manually configuring TCP/IP parameters from the printer control panel
Use manual configuration to set an IP address, subnet mask, and default gateway.
Setting an IP address
  1. Press Menu to enter the MENUS.
  2. Press (Down button) to highlight CONFIGURE DEVICE.
  3. Press (Checkmark) to select CONFIGURE DEVICE.
  4. Press (Down button) to highlight I/O.
  5. Press (Checkmark) to select I/O.
  6. Press (Down button) to highlight EMBEDDED JETDIRECT MENU.
  7. Press (Checkmark) to select EMBEDDED JETDIRECT MENU.
  8. Press (Down button) to highlight TCP/IP.
  9. Press (Down button), highlight IPV4 SETTINGS, and then press (Checkmark) to select IPV4 SETTINGS.
  10. Press (Checkmark) and select CONFIG METHOD.
  11. Press (Down button) to highlight MANUAL, and then press (Checkmark).
  12. Press (Down button) to highlight MANUAL SETTINGS.
  13. Press (Checkmark) to select MANUAL SETTINGS.
  14. Press (Down button) to highlight IP Address:.
  15. Press (Checkmark) to select IP Address:.
    The first of three sets of numbers is highlighted. If a number is not highlighted, a highlighted empty underscore appears.
  16. Press (Up button) or (Down button) to increase or decrease the number for configuring the IP address.
  17. Press (Checkmark) to move to the next set of numbers.
  18. Repeat steps 15 and 16 until the correct IP address is entered.
  19. Press the Menu button to return to the Ready state.
Setting the subnet mask
  8. Press (Down button) to highlight the TCP/IP menu.
  9. Press (Checkmark) to select TCP/IP.
  10. Press (Down button), highlight IPV4 SETTINGS, and then press (Checkmark) to select IPV4 SETTINGS.
  11. Press (Checkmark) to highlight MANUAL SETTINGS.
  12. Press (Checkmark) to select MANUAL SETTINGS.
  13. Press (Down button) to highlight SUBNET MASK.
  14. Press (Checkmark) to select SUBNET MASK.
    The first of three sets of numbers are highlighted.
  15. Press (Up button) or (Down button) to increase or decrease the number for configuring the subnet mask.
  16. Press (Checkmark) to move to the next set of numbers.
  17. Repeat steps 14 and 15 until the correct subnet mask is entered.
  18. Press the Menu button to return to the Ready state.
Setting the default gateway
  10. Press (Down button) to highlight MANUAL SETTINGS.
  11. Press (Checkmark) to select MANUAL SETTINGS.
  12. Press (Down button) to highlight DEFAULT GATEWAY.
  13. Press (Checkmark) to select DEFAULT GATEWAY.
    The first set of the three sets of numbers shows the default settings. If there is not a number highlighted, a highlighted empty underscore appears.
  14. Press (Up button) or (Down button) to increase or decrease the number for configuring DEFAULT GATEWAY.
  15. Press (Checkmark) to move to the next set of numbers.
  16. Repeat steps 15 and 16 until the correct subnet mask is entered.
  17. Press the Menu button to return to the Ready state.
Country: Flag Serbia
