HP Designjet Z3100 Photo Printer Series - Change the graphic language setting
To be able to change the graphic language setting you must install the HP-GL/2 upgrade.
  warning:
You should not need to change the default graphic language setting (Automatic), and you are not recommended to do so.
Change the graphic language setting from the HP Easy Printer Care and HP Printer Utility applications with the following steps.
  1. Under Windows, select the Settings tab then Printer settings, Printing preferences.
    Under Mac OS, select Configuration then Printer settings, Configure printer settings, Printing preferences.
  2. Select one of the following options.
    • Select Automatic to let the printer determine which type of file it is receiving. This setting works for most software applications.
    • Select HP-GL/2 only if you are sending a file of the appropriate type directly to the printer, without going through a printer driver.
You can change the graphic language setting from the front panel. Press the Menu key to return to the main menu the select the Setup menu icon , then Select graphics language. Select the desired option and press the OK key to set the value.
The setting selected through the HP Easy Printer Care (Windows) or HP Printer Utility (Mac OS) overrides the setting select by the front pane.
