HP Designjet Z3100 Photo Printer Series - Access the Embedded Web Server
The Embedded Web Server enables you to manage your printer remotely using an ordinary Web browser running on any computer.
To use the Embedded Web Server, you must have a TCP/IP connection to your printer.
The following browsers are known to be compatible with the Embedded Web Server:
  • Internet Explorer 5.5 or later, for Windows
  • Internet Explorer 5.1 or later, for Mac OS X
  • Netscape Navigator 6.01 or later
  • Mozilla 1.5 or later
  • Mozilla Firefox 1.0 or later
  • Safari
To access the Embedded Web Server on any computer, open your Web browser and give the IP address of your printer. You can find out the address of your printer (starting with http:) from the front-panel display, by looking at the status screen.
Figure : Status screen
