    Fix Windows 10 Update Issues
HP Designjet Z3100 Photo Printer Series - Printer software
The following software is provided with your printer:
  • The PCL3 raster driver, your main printer driver
  • The HP Easy Printer Care (Windows) or HP Printer Utility (Mac OS), allows you to:
    • Manage the printer including color with the HP Color Center
    • View the status of the ink cartridges, the printheads, and the paper
    • View job accounting information
    • Update the printer's firmware
    • Change various printer settings (in the Settings tab)
    Windows XP Professional x64 Edition does not support HP Easy Printer Care, therefore it cannot be installed with your printer's installer.
  • The Embedded Web Server, runs in the printer and enables you to use a Web browser on any computer to perform the HP-GL/2 Upgrade and to check ink levels and printer status.
  • The RTL and HP-GL/2 driver for Windows, needed if you have the HP-GL/2 Upgrade
