HP iPAQ rx4000 Mobile Media Companion series - Creating or Changing a Signature
  1. Tap Start>Messaging.
  2. Tap Menu>Tools>Options.
  3. Tap the Accounts tab >Signatures.
  4. Select the account for which you want to create or change a signature.
  5. Select the Use signature with this account check box if it is not already selected.
  6. Select the Use when replying and forwarding check box if wanted.
  7. Enter a signature in the box.
To stop using a signature, clear the Use signature with this account check box.
You can use a different signature with each Messaging account.
Country: Flag Serbia
