    Fix HP Printer issue on macOS
HP Compaq dc7700 Business PC Small Form Factor Specifications
Product description
HP Compaq dc7700 Business Desktop PCs offer technologies that solve customers’ problems, quality that is built in to help keep your business up and running smoothly, and expertise to provide superior service and value.
Product Features
Feature
Processors
  • Intel Celeron D 352 Processor (3.20-GHz, 512-K L2 cache, 533-MHz FSB)
  • Intel Celeron D 360 Processor (3.46-GHz, 512-K L2 cache, 533-MHz FSB)
Intel Pentium 4 Processors with HT Technology:
  • Intel Pentium 4 524 Processor (3.06-GHz, 1-MB L2 cache, 533-MHz FSB).
  • Intel Pentium 4 531 Processor (3.0-GHz, 1-MB L2 cache, 800-MHz FSB).
  • Intel Pentium 4 541 Processor (3.2-GHz, 1-MB L2 cache, 800-MHz FSB)
  • Intel Pentium D Processors:
  • Intel Pentium D 915 Processor (2.8-GHz, 2x1MB L2 cache, 800-Mhz FSB
  • Intel Pentium D 925 Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB)
  • Intel Pentium D 945 Processor (3.4-GHz, 2x2MB L2 cache, 800-MHz FSB)
  • Intel Core 2 Duo Processors
  • Intel Core 2 Duo E6300 Processor (1.86-GHz, 2 MB L2 cache, 1066-MHz FSB)
  • Intel Core 2 Duo E6400 Processor (2.13-GHz, 2 MB L2 cache, 1066-MHz FSB)
  • Intel Core 2 Duo E6600 Processor (2.40-GHz, 4 MB L2 cache, 1066-MHz FSB)
  • Intel Core 2 Duo E6700 Processor (2.66-GHz, 4 MB L2 cache, 1066-MHz FSB)
Intel processor numbers are not a measure of performance. Processor numbers differentiate features within each processor family, not across different processor families. USDT
Intel Q965 Express chipset
Hard drives
One or two of the following
  • 80-GB SATA 3.0-Gb/s Hard Drive (8MB Cache,7200 rpm).
  • 160-GB SATA 3.0-Gb/s Hard Drive (8MB Cache,7200 rpm).
  • RAID 80-GB SATA 3.0-Gb/s Hard Drive (7200 rpm)
  • RAID 160-GB SATA 3.0-Gb/s Hard Drive (7200 rpm)
  • 250-GB SATA 3.0-Gb/s Hard Drive (7200 rpm).
  • 2nd hard drive, 80-GB SATA 3.0-Gb/s Hard Drive (8MB Cache7200 rpm).
  • 2nd hard drive, 160-GB SATA 3.0-Gb/s Hard Drive (8MB Cache,7200 rpm).
  • 2nd hard drive, 250-GB SATA 3.0-Gb/s Hard Drive (8MB Cache,7200 rpm).
System memory Configurations
One of the following
  • 512-MB DDR2 Synch Dram PC2-6400 (800-MHz) Non ECC (1 x 512)
  • 512-MB DDR2 Synch Dram PC2-6400 (800-MHz) Non ECC (2 x 256)
  • 1-GB DDR2 Synch Dram PC2-6400 (800-MHz) Non ECC (1 x 1GB)
  • 1-GB DDR2 Synch Dram PC2-6400 (800-MHz) Non ECC (2 x 512)
  • 2-GB DDR2 Synch Dram PC2-6400 (800-MHz) Non ECC (2 x 1GB)
  • 2-GB DDR2 Synch Dram PC2-6400 (800-MHz) Non ECC (4 x 512)
  • 3-GB DDR2 Synch Dram PC2-6400 (800-MHz) Non ECC (3 x 1GB)
  • 4-GB DDR2 Synch Dram PC2-6400 (800-MHz) Non ECC (4 x 1GB)
  • 256-MB DDR2 Synch Dram PC2-5300 (667-MHz) Non ECC (1 x 256)
  • 12-MB DDR2 Synch Dram PC2-5300 (667-MHz) Non ECC (1 x 512)
  • 512-MB DDR2 Synch Dram PC2-5300 (667-MHz) Non ECC (2 x 256)
  • 1-GB DDR2 Synch Dram PC2-5300 (667-MHz) Non ECC (1 x 1GB)
  • 1-GB DDR2 Synch Dram PC2-5300 (667-MHz) Non ECC (2 x 512)
  • 2-GB DDR2 Synch Dram PC2-5300 (667-MHz) Non ECC (2 x 1GB)
  • 2-GB DDR2 Synch Dram PC2-5300 (667-MHz) Non ECC (4 x 512)
  • 3-GB DDR2 Synch Dram PC2-5300 (667-MHz) Non ECC (3 x 1GB)
  • 4-GB DDR2 Synch Dram PC2-5300 (667-MHz) Non ECC (4 x 1GB)
Removable storage
Diskette Drives
  • 1.44-MB Diskette Drive
Media Reader
  • Media Reader HP 16-in-1 (PCI card supplies internal USB connection)
Optical storage
Optical Drives
  • SATA CD-RW/DVD-ROM Combo
  • SATA DVD-ROM Drive.
  • SATA DVD+/-RW (DL/DF) LightScribe Drive
Slimline Optical
  • Drives PATA CD-ROM Slim Drive
  • PATA CD-RW/DVD-ROM Combo Slim Drive
  • PATA DVD+/-RW Slim Drive
  • PATA DVD-ROM Slim Drive
Keyboard one of tha followings - One of the following
  • HP PS/2 Standard Keyboard
  • HP USB Standard Keyboard
  • HP USB Smartcard Keyboard
Mouse - One of the following
  • HP PS/2 2-Button Scroll Mouse
  • HP PS/2 2-Button Optical Scroll Mouse
  • HP USB 2-Button Optical Scroll Mouse
  • HP USB 2-Button Scroll Mouse
Audio
  • Integrated High Definition audio with Realtek 4-channel ALC262 codec (all ports are stereo)
  • Microphone and Headphone front ports.
  • Microphone rear port*
  • Line-out and Line-In rear ports*
  • Multistreaming capable*
  • Internal Speaker.
*Rear audio ports are re-taskable as Line-in, Line-out, or Microphone-in. External speakers must be powered externally. Multistreaming can be enabled in the Realtek control panel to allow independant audio streams to be sent to/from the front and rear jacks. This allows for different audio applications to use separate audio ports on the system. For example, the front jacks could be used with a headset for a communications application while the rear jacks are being used with external speakers and a multimedia application.
NIC
  • Intel 82566DM Gigabit Network Connection (integrated on system board)
  • Intel PRO/1000 PT PCIe Gigabit NIC (full height bracket)
  • Intel PRO/1000 PT PCIe Gigabit NIC (low profile bracket)
  • Broadcom NetXtreme Gigabit PCIe NIC (full height bracket)
  • Broadcom NetXtreme Gigabit PCIe NIC (low profile bracket)
    * Requires optional PCIe riser card.
Modem
  • 2006 Agere PCI 56K International SoftModem (full height)*
  • 2006 Agere PCI 56K International SoftModem (low profile)
*Requires optional PCI riser card.
Graphics
  • Integrated Intel Graphics Media Accelerator 3000
  • DVI ADD2 SDVO single head Graphics Adapter for USDT (PCIe x16)
  • ATI RADEON X1300 256MB low profile PCIe Card, DVI w/TV
  • NVIDIA Quadro NVS 280 64-MB PCI dual head VGA Card
  • NVIDIA Quadro NVS 285 (128MB DH) PCIe x16 VGA Card
    NVIDIA Quadro NVS 285 and NVS 280 graphics cards can be combined to provide support for four monitors.
Security
  • 1.2 TPM Embedded Security Chip integrated.
  • HP ProtectTools Embedded Security Software
  • Drive Lock
  • Serial, Parallel, USB Enable/Disable (via BIOS)
  • Removable Media Write/Boot Control
  • Power-On Password (via BIOS)
  • Setup Password (via BIOS)
  • Solenoid Lock (electronic hood lock)
  • Hood Removal Sensor
Miscellaneous
  • HP FireWire / IEEE 1394 PCI Card (full height)*
  • HP FireWire / IEEE 1394 PCI Card (low profile)
  • PCI riser card – adds 2 full-heigth PCI slots
  • Tower stand
  • 2nd serial port adapter (low profile)
*Low profile slots are unusable with riser card installed
Sevice and support
On-site Warranty and Service Note 1: This three-year (3-3-3), limited warranty and service offering delivers three years of parts, labor and on-site repair. Response time is next business-day Note 2 and includes free telephone support Note 3 24 x 7. Global coverage Note 2 ensures that any product purchased in one country and transferred to another non-restricted country will remain fully covered under the original warranty and service offering. Some countries/regions do not offer one year onsite and labor.
1: Terms and conditions may vary by country. Certain restrictions and exclusions apply. 2: On-site service may be provided pursuant to a service contract between HP and an authorized HP third-party provider, and is not available in certain countries. Global service response times are based on commercially reasonable best effort and may vary by country.3: Technical telephone support applies only to HP-configured, HP and HP-qualified, third-party hardware and software. Toll-free calling and 24 x 7 support may not be available in some countries.
Software/OS
Feature
Operating System - One of the following
  • Genuine Windows XP Professional SP2
  • Genuine Windows XP Home SP2
  • FreeDOS
  • Windows Vista Capable – Not all Windows Vista features are available for use on all Windows Vista Capable PCs. All Windows Vista Capable PCs will run the core experiences of Windows Vista, such as innovations in organizing and finding information, security, and reliability. Some features available in premium editions of Windows Vista -- like the new Windows Aero™ user interface -- require advanced or additional hardware.
Microsoft Windows NT 4.0 and Microsoft Windows 2000 are not available on these systems. Some drivers for Windows 2000 are available for download.
Value-added Software (not included with FreeDOS)
  • HP ProtectTools Security Solutions
  • Symantec AntiVirus 10.0 with 60 day Live Update
  • Altiris Deployment Solution Agent Subscription
  • HP OpenView Configuration Management
  • Solutions Agent
  • Microsoft Office 2003 Basic
  • Microsoft Office 2003 Professional
  • HP Insight Diagnostics (on documentation CD)
  • Microsoft Office 2003 Small Business
  • Computer Setup Utility
  • Microsoft Internet Explorer with Google Toolbar
  • HP Backup and Recovery Manager
Value-added Services and Features
  • HP Stable Platform Program
  • Factory Express Deployment and Lifecycle Services
  • Business-to-Business Portals
  • TPM 1.2 Security
  • HP Global Series Services
  • Tool-less Serviceability
