HP LaserJet M4345 MFP Series Products - Copy two-sided documents
Copying two-sided documents manually
Copies resulting from this procedure are printed on one side, and need to be hand-collated.
  1. Load the documents to be copied into the document feeder input tray with the first page facing up, and with the top of the page leading into the document feeder.
  2. Touch Start Copy. The odd-numbered pages are copied and printed.
  3. Remove the stack from the document feeder output tray and reload the stack with the last page facing up, and with the top of the page leading into the document feeder.
  4. Touch Start Copy. The even-numbered pages are copied and printed.
  5. Collate the odd- and even-numbered printed copies.
Copy two-sided documents automatically (duplex models only)
The default copy setting is one-sided to one-sided. Use the following procedures to change the setting so you can copy from or to documents that are two-sided.
Make two-sided copies from one-sided documents
  1. Load the documents to be copied into the document feeder with the first page facing up, and with the top of the page leading.
  2. On the control panel, touch Copy.
  3. Touch Sides.
  4. Touch 1-sided original, 2-sided output.
  5. Touch OK.
  6. Touch Start Copy.
Make two-sided copies from two-sided documents
    Two-sided copying from the flatbed scanner glass is not supported.
  3. Touch Sides.
  4. Touch 2-sided original, 2-sided output.
  5. Touch OK.
Make one-sided copies from two-sided documents
  3. Touch Sides.
  4. Touch 2-sided original, 1-sided output.
  5. Touch OK.
