HP xw6400 Workstation Specifications
Product Description
With one of the smallest dual-processor form factors in the industry, the HP xw6400 Workstation fits neatly into cramped work spaces. Industry-leading, tool-less chassis design eases servicing, upgrading, and maintenance.
Product features
Feature
Form factor
Rackable minitower
Processors
Dual 64-bit Intel Xeon series 5100 processors
Intel 5000X
Memory
Up to 8 GB of ECC registered 4 channel DDR 667 MHz Fully Buffered DIMMs via 2 GB DIMMs in 4 DIMM slots; up to 16 GB of memory via 4 GB DIMMs (expected availability, October 2006)
Drive controller
Integrated quad channel SATA 3 Gb/s controller with RAID 0 or 1 capability
Hard drives
Up to 3 SATA drives, 1.5 TB max.; 80 GB (7200 rpm) SATA 3 Gb/s, or 160, 250, 500 GB (7200 rpm) SATA 3 Gb/s NCQ; 80, 160 (10K rpm) SATA 1.5 Gb/s NCQ Up to 3 Serial Attached SCSI (SAS) drives, 483 GB max.; 146 GB (10K rpm) or 73, 146 GB (15K rpm)
Optical drives
48X CD-ROM, 16X DVD-ROM, 48X CD-RW/DVD combo, 16X DVD+/-RW DL with LightScribe Direct Disc Labeling (Microsoft Windows XP Professional only, requires LightScribe media for labeling)
Graphics
  • Professional 2D: NVIDIA Quadro NVS 285 (128 MB – up to 2 pro 2D cards supported; NVS 285/285, 285/440, or 440/440) NVIDIA Quadro NVS 440 (256 MB quad display & up to 2 pro 2D cards supported; see above)
  • Entry 3D: NVIDIA Quadro FX 560 (128 MB), ATI FireGL V3300 (128 MB)
  • Mid-range 3D: NVIDIA Quadro FX 1500 (256 MB), ATI FireGL V7200 (256 MB)
  • High-end 3D: NVIDIA Quadro FX 3500 (256 MB), NVIDIA Quadro FX 4500 (512 MB) with opt. Quadro G-Sync card
Audio
Integrated High Definition audio with Jack Retasking technology, opt. PCI Sound Blaster X-Fi XtremeMusic
Network
Integrated Broadcom 5752 Gigabit PCIe LAN on Motherboard, opt. Broadcom 5751 Gigabit PCIe NIC, opt. Intel Pro/1000 PT PCIe NIC
Ports
  • Front: 2 USB 2.0, 1 headphone, 1 microphone line in, 1 IEEE 1394A (requires PCI card to enable functionality)
  • Rear: 5 USB 2.0, 1 standard serial port, 1 parallel port, PS/2 keyboard and mouse, 1 RJ-45 LAN, 1 audio line in, 1 audio line out, 1 microphone line in
  • Internal: 1 USB 2.0
Input devices
USB or PS/2 keyboard; choice of 2-button scroll mouse (USB optical or PS/2 mechanical); 3-button mouse (USB optical); USB SpaceMouse; USB SpaceBall, USB SpacePilot, USB SmartCard keyboard, media reader
Dimensions (H x W x D)
17.3 inches (44.1 cm) × 6.5 inches (16.5 cm) × 17.3 inches (44.1 cm)
Power
575 Watts
Monitors
  • HP L1955 19-inch flat panel
  • HP LP2065 20.1-inch flat panel
  • HP LP2465 24-inch flat panel
Three years next business day, parts, labor, and 8x5 phone support; terms and conditions may vary, certain restrictions apply
Software/OS
Feature
Operating systems
  • Preinstalled 32-bit: Microsoft Windows XP Professional
  • Preinstalled 64-bit: Microsoft Windows XP Professional x64 Edition
  • Preinstalled 64-bit: Red Hat Enterprise Linux WS 4
  • Optional 32-bit or 64-bit: Red Hat Enterprise Linux WS 3 or WS 4 and HP Linux Installer Kit
Available software
Not supported on Red Hat Linux
  • Optional Symantec Norton AntiVirus
  • CA eTrust 64-Bit Anti-Virus Software
  • Optional Microsoft Office 2003 Basic Software
  • Optional Microsoft Office 2003 Personal Software
  • Optional Microsoft Office 2003 Professional Software
  • Optional Microsoft Office 2003 Small Business
  • HP Performance Tuning Framework
  • HP Client Manager Software v6.0
