HP Photosmart E427 and E427v Digital Cameras - Product Specifications
Figure : HP Photosmart E427 and E427v digital camera
Printer model
Part number
HP Photosmart E427 digital camera
L2437A
HP Photosmart E427v digital camera
L2438A
Feature
Resolution
Still pictures:
  • 6.0MP (2654 x 1955) total pixel count
  • 6.4 MP (2560 x 1920) effective pixel count
Video clips:
  • Quarter Video Graphics Array (QVGA) 320 by 240 total pixel count, 30 frames/sec
Sensor
Diagonal 7.26 mm (1/2.5-inch, 4:3 format) CCD
Color depth
30 bit (10 bits by 3 colors). 30 bit images are transformed into an optimized 24 bit image and stored in the JPEG format. This transformation results in no discernible change to color or detail in the stored image, and allows the image to be read by computers.
Lens
Fixed focal length, f/3.5
Viewfinder
None
Zoom
5x digital zoom
Focus
Fixed focus
  • Macro—600mm to 1m
  • Normal—1m to infinity
Shutter speed
1/1000 to 2 seconds
Built-in flash
Yes, 6-second typical recharge time
Flash working range
Maximum with ISO Speed set to Auto: 5 meters (16.5 feet)
Storage
  • 16MB internal flash memory, not all of which is available for storing images and video clips
  • Slot for memory card.
  • This camera supports standard and high speed, HP-branded Secure Digital (SD) memory cards, 16MB to 1GB.
  • The number of images or video clips that can be saved in memory depends on the Image Quality settings
Image display
5.08 cm (2.0 in) color LTPS TFT LCD with backlight, 153,600 pixels (640 by 240) total pixel count
Compression format
  • JPEG (EXIF) for still images
  • EXIF 2.2 for still images with embedded audio
  • Motion JPEG for video clips
Interface
USB Mini B connector, USB 2.0 full speed
Standards
  • PTP and MSDC
  • NTSC/PAL
  • JPEG
  • Motion JPEG
  • DPOF 1.1
  • EXIF 2.2
  • DCF 1.0
  • DPS
power
Typical power usage: 2.5 Watts (with Image Display on). 5 Watts peak power usage.
Power sources include two AA non-rechargeable Alkaline or Photo Lithium batteries or two AA rechargeable NiMH batteries.
External body dimensions (L x W x H)
Measurements with camera off and lens retracted (width, depth, height):
  • 95.6 mm (W) by 24.2 mm (D) by 55.2 mm (H)
  • 3.76 in (W) by .95 in (D) by 2.17 in (H)
105 grams (3.7 ounces) without batteries
Temperature range
  • Operational:
    0 to 50 degrees C (32 to 122 degrees F) at 15 to 85 percent relative humidity
  • Storage:
    -30 to 65 degrees C (-22 to 149 degrees F) at 15 to 90% relative humidity
Memory capacity
Not all 16MB of internal memory is available for storing images, because some memory is used for internal camera operations. The actual file sizes and number of still images that can be stored in internal memory or on a memory card will vary depending on the content of each still image and the length of any associated audio clip.
Image quality
The following table lists the approximate number and average size of still images that can be stored in internal memory when the camera is set to different Image Quality settings
6MP Best
8 images (1.2MB each)
Normal (6MP)
10 images (1.0MB each)
4MP
18 images (600KB each)
2MP
21 images (500KB each)
VGA
95 images (120KB each)
The values shown are for images without audio clips. Thirty seconds of audio adds 470KB to the file size.
