HP LaserJet 5200 Series Printers - Supplies and Accessories
This document provides information about ordering parts, supplies, and accessories. Use only parts and accessories that are specifically designed for this printer.
Ordering parts, accessories, and supplies
Several methods are available for ordering parts, supplies, and accessories:
Ordering directly from HP
You can obtain the following items directly from HP:
Ordering through service or support providers
To order a part or accessory, contact an HP-authorized service or support provider. (See HP Customer Care.)
Ordering directly through the embedded Web server (for printers that are connected to a network)
Use the following steps to order printing supplies directly through the embedded Web server. (See Using the embedded Web server for an explanation of this feature.)
To order directly through the embedded Web server (for printers that are connected to a network)
  1. In the Web browser on the computer, type the IP address for the printer. The printer status window appears.
  2. Select the Setting tab at the top of the window.
  3. If asked to provide a password, type the password.
  4. On the left side of the Device Configuration window, double-click Order Supplies. This provides a URL from which to purchase consumables. Supplies information with part numbers and printer information is provided.
  5. Select the part numbers that you want to order and follow the instructions on the screen.
Ordering directly through the HP Easy Printer Care software (for printers that are directly connected to a computer)
Use the HP Easy Printer Care software to order supplies and accessories directly from the computer. Click Supplies Ordering, and then click Shop Online for Supplies.
Part numbers
The following list of accessories was current at the time of printing. Ordering information and availability of the accessories might change during the life of the printer.
Paper-handling accessories
Item
Part number
Optional 500-sheet tray and feeder unit (tray 3)
Optional tray to increase paper capacity. Holds Letter, A4, Legal, A5, B5 (JIS), Executive, and 8.5 x 13 paper sizes.
Note: This tray is included with the HP LaserJet 5200dtn printer.
Q7548A
Optional duplexer
Provides automatic printing on both sides of the paper.
Q7549A
Print cartridge
Item
Part number
HP LaserJet print cartridge
12,000-page cartridge
Q7516A
Memory
Item
Part number
100-pin 133MHz DDR DIMM
Boosts the ability of the printer to handle large or complex print jobs.
32 MB
Q7713A
48 MB
Q7714A
64 MB
Q7715A
128 MB
Q7718A
256 MB
Q7719A
512 MB
Q7720A
Cables and interfaces
Item
Part number
Enhanced I/O (EIO) cards
HP Jetdirect print server multi-protocol EIO network cards:
HP Jetdirect 620n Fast Ethernet (10/100Base-TX) print server
J7934A
HP Jetdirect 680n 802.11b wireless internal print server
J6058A
HP Jetdirect Connectivity card for USB, serial, and LocalTalk connections
J4135A
Parallel cables
2-meter IEEE 1284-B cable
C2950A
3-meter IEEE 1284-B cable
C2951A
USB cable
2-meter A to B cable
C6518A
Print media
For more information about media supplies, go to http://www.hp.com/go/ljsupplies.
Item
Part number
HP Soft Gloss laser paper
For use with HP LaserJet printers. This is coated paper, good for business documents with high impact, such as brochures, sales material, and documents with graphics and photographic images.
Specifications: 32 lb (120 g/m2).
Letter (220 x 280 mm), 50 sheets/box
C4179A/Asia-Pacific countries/regions
A4 (210 x 297 mm), 50 sheets/box
C4179B/Asia-Pacific countries/regions and Europe
HP LaserJet tough paper
For use with HP LaserJet printers. This satin-finish paper is waterproof and tear-proof, yet doesn't compromise on print quality or performance. Use it for signs, maps, menus, and other business applications.
Letter (8.5 x 11 in), 50 sheets to a carton
Q1298A/North America
A4 (210 x 297 mm), 50 sheets to a carton
Q1298B/Asia-Pacific countries/regions and Europe
HP Premium Choice LaserJet paper
HP's brightest LaserJet paper. Expect spectacular color and crisp black from this paper that is extra smooth and brilliantly white. This is ideal for presentations, business plans, external correspondence and other high-value documents
Specifications: 98 bright, 32 lb. (75 g/m2).
Letter (8.5 x 11 in), 500 sheets/ream, 10-ream carton
HPU1132/North America
Letter (8.5 x 11 in), 250 sheets/ream, 6-ream carton
HPU1732 North America
A4 (210 x 297 mm), 5-ream carton
Q2397A/Asia-Pacific countries/regions
A4 (210 x 297 mm), 250 sheet/ream, 5-ream carton
CHP412/Europe
A4 (210 x 297 mm), 500 sheet/ream, 5-ream carton
CHP410/Europe
A4 (210 x 297 mm), 160 g/m2, 500 sheet/ream, 5-ream carton
CHP413/Europe
HP LaserJet paper
For use with HP LaserJet printers. This is good for letterhead, high-value memos, legal documents, direct mail, and correspondence.
Specifications: 96 bright, 24 lb (90 g/m2).
HPJ1124/North America
Legal (8.5 x 14 in), 500 sheets/ream, 10-ream carton
HPJ1424/North America
Letter (220 x 280 mm), 500 sheets/ream, 5-ream carton
Q2398A/Asia-Pacific countries/regions
A4 (210 x 297 mm), 500 sheets/ream, 5-ream carton
Q2400A/Asia-Pacific countries/regions
CHP310/Europe
HP Printing paper
For use with HP LaserJet and inkjet printers. This has been created especially for small and home offices. It is heavier and brighter than copier paper.
Specifications: 92 bright, 22 lb.
HPP1122/North America and Mexico
Letter (8.5 x 11 in), 500 sheets/ream, 3-ream carton
HPP113R/North America
CHP210/Europe
A4 (210 x 297 mm), 300 sheets/ream, 5-ream carton
CHP213/Europe
HP Multipurpose paper
For use with all office equipment-laser and inkjet printers, copiers, and fax machines. This has been created for businesses that want one paper for all their office needs. It is brighter and smoother than other office papers.
Specifications: 90 bright, 20 lb (75 g/m2).
Letter (8.5 x 11 in), 500 sheets/ream, 5-ream carton
Letter (8.5 x 11 in), 250 sheets/ream, 12-ream carton
Letter (8.5 x 11 in), 3-hole, 500 sheets/ream, 10-ream carton
HPM1120/North America
HPM115R/North America
HP25011/North America
HPM113H/North America
HPM1420/North America
HP Office paper
For use with all office equipment-laser and inkjet printers, copiers, and fax machines. This is good for high-volume printing.
Specifications: 84 bright, 20 lb (75 g/m2).
HPC8511/North America and Mexico
HPC3HP/North America
HPC8514/North America
Letter (8.5 x 11  in), Quick Pack; 2,500-sheet carton
HP2500S/North America and Mexico
Letter (8.5 x 11 in), Quick Pack 3-hole; 2,500-sheet carton
HP2500P/North America
Q2408A/Asia-Pacific countries/regions
Q2407A/Asia-Pacific countries/regions
CHP110/Europe
A4 (210 x 297 mm), Quick Pack; 2500 sheets/ream, 5-ream carton
CHP113/Europe
HP Office recycled paper
Satisfies U.S. Executive Order 13101 for environmentally preferable products.
Specifications: 84 bright, 20 lb, 30% post-consumer content.
HPE1120/North America
HPE113H/North America
HPE1420/North America
HP LaserJet transparencies
For use only with HP LaserJet monochrome printers. For crisp, sharp text and graphics, rely on the only transparencies specifically designed and tested to work with monochrome HP LaserJet printers.
Specifications: 4.3-mil thickness.
92296T/North America, Asia-Pacific countries/regions, and Europe
922296U/Asia-Pacific countries/regions and Europe
