HP Notebook PCs - Steps for Removing and Replacing the Battery
This document provides instructions for the removal and replacement of the battery for the dv5000, dv5100, dv5200 and dv5400 series notebook PCs.
To view the video press the Play button on the player control bar below the video.
To stop the video press the Pause button on the player control bar below the video.
To restart the video press the Rewind button on the player control bar below the video.
Flash Player from Macromedia is required to view this video. Visit the Macromedia website (in English) to download and install Flash Player.
Step 1 - Remove the Battery
  1. Slide and hold the battery release latch to the unlock position.
  2. Lift the front edge of the battery and remove it from battery bay.
Step 2 - Replace the Battery
  1. Toe the rear edge of the battery into the base enclosure.
  2. Lower the front edge of the battery and press the battery into the battery bay until the release latch clicks.
