    Windows 11 Upgrade Guide
     Connect with HP support faster, manage all of your devices in one place, view warranty information and more. Sign up for an HP account
HP Photosmart Pro B9180 and B9180gp Photo Printers - Install the Ink Cartridges
Follow the instructions below to install the ink cartridges.
Install the cartridges
All eight ink cartridges must be correctly installed for the printer to work.
  1. Ensure that all the printer doors are closed.
  2. Open the ink cartridge door by pressing the raised bumps until the door clicks open.
    Figure : Opening the ink cartridge door
  3. Before unwrapping the ink cartridges, hold each one vertically (with one of the short ends up) and shake it well, at least six times.
  4. Unwrap the ink cartridges.
    Figure : Opening the cartridges
  5. Insert each cartridge into its color-coded stall. Press firmly on the cartridges to ensure proper contact.
    Figure : Inserting the cartridges
  6. Close the ink cartridge door and wait a few moments.
    The printer primes the ink cartridges to start the flow of ink and purge air from the ink line.
