Choose acceptable media, load originals, and scan one-sided or two-sided documents using the automatic document feeder (ADF).
- ${title}
- ${title}
- ${title}
- ${title}
HP Scanjet 8270 Scanner - Scan From the Automatic Document Feeder (ADF)
Scanning from the ADF
Choosing acceptable media
The ADF works best when the originals meet the following specifications. If the
originals do not meet these criteria, scan from the scanner glass.
A4-, letter-, or legal-size paper.
Custom-size paper ranging from 88.9 x 127 mm (3.5 x 5.0 inches) to 216 x 356 mm (8.5 x 14 inches).
Media weights from 60 to 90 (g/m2) (16 to 24 pounds).
Media that is square- or rectangular-shaped and is in good condition.
Media that is free of perforations or punch holes.
Media that does not contain wet glue, correction fluid, or ink.
note:Avoid putting photos, multi-part forms, transparencies, magazine pages, gum-backed pages, and lightweight paper in the ADF.
Placing the originals in the ADF
Before placing an original in the ADF, check for and remove curls, wrinkles, staples,
paper clips, and any other attached material. Make sure that sheets are not stuck
together.
Place a stack of similarly sized pages face-up in the input tray of the ADF, with the first page on top. The top of the page should point towards the document feeder.Figure : Loading originals in the ADF
Adjust the paper guides to center the stack.
Scanning one-sided documents from the ADF
Press the Destination (
) button until the desired destination displays on the LCD.
Press the Scan Document To (
) button.
Follow the instructions that display on the screen to complete the scan.
Scanning two-sided documents from the ADF
Slide the Duplex switch located near the ADF to the left. This puts the scanner in Duplex mode.
Open HP Solution Center.
Click Start.
Click Programs.
Click HP.
Click HP Solution Center.
Click Scan Document. The HP Scanning dialog box displays.
Click Scan.
After the scan is complete, click Done. HP Solution Center sends the scanned file to the specified location.
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Serbia
- ${title}
hp-hero-support-search
- ${title}
