HP Scanjet 8270 Scanners - Product Specifications
Model number
Product Name
Model Number
HP Scanjet 8270 scanner
L1975A
Serial number location
The serial number is located on the bottom of the unit.
Scanner specifications
Name
Scanner type
Flatbed with transparent materials adapter (TMA)
Weight, without the lid
2.79 kilograms (6.2 pounds)
Maximum original size
296 x 494 x 73 mm (11.7 x 19.8 x 2.9 inches)
Scanning element
Charged-coupled device
Interface
USB 2.0 high-speed
Optical resolution
4800 dpi
Selectable resolution
12 to 999,999 dpi at 100 percent scaling
AC line voltage
100 to 240 V, 50/60 Hz
Power consumption and regulatory information
For power consumption data, see the regulatory_supplement.htm file on the HP Photosmart Software CD.
Energy efficiency
The HP scanner is ENERGY STAR compliant. As an ENERGY STAR partner, the Hewlett-Packard Company has determined that this product meets the ENERGY STAR guidelines for energy efficiency.
Transparent materials adapter (TMA) specifications
Name
Media types and capacity
  • Slides: Up to three 35 mm slides mounted on a frame that is 1.05 to 1.9 mm (0.04 to 0.07 inch) thick and 49.8 to 50.8 mm (1.96 to 2.0 inch) on any side
  • Negatives: Up to four frames on a 35 mm negative strip
Size
565 x 320 x 64 mm (22.2 x 12.6 x 2.5 inches)
1.6 kilograms (3.5 pounds)
Power requirements
16 Vdc, 425 mA, 6.8 watts (supplied by scanner)
Automatic document feeder (ADF) specifications
Name
Size
584 x 318 x 89 mm (23.0 x 12.5 x 3.5 inches)
Weight (with TMA)
2.7 kilograms (6.0 pounds)
Optical resolution
600 dpi
Paper tray capacity
50 pieces of 75 g/m2 (20 pound bond)
Maximum paper size
216 x 356 mm (8.5 x 14 inches)
Minimum paper size
89 x 127 mm (3.5 x 5 inches)
Maximum paper weight
90 g/m2 (24 pound)
Power requirements
  • 32 Vdc, 1200 mA
  • 16 Vdc, 425 mA
  • 3300 mVdc, 3.3 Vdc, 300 mA (supplied by scanner)
Environmental specifications
Operating conditions
Name
Temperature
10 to 35 degrees C (50 to 95 degrees F)
Relative humidity
15 to 80 percent non-condensing
Storage conditions
Name
Temperature
-40 to 70 degrees C (-40 to 158 degrees F)
Relative humidity
Up to 90 percent non-condensing
Minimum system requirements
Windows
  • Computer with Intel Pentium II 233 MHz or equivalent Celeron processor
  • Universal Serial Bus (USB) port
  • Windows 98, 98 SE, Me, XP Home or Professional, or 2000 Professional Edition
  • 64 MB RAM for Windows 98, 98 SE, and Me; 128 MB RAM for Windows 2000 and XP
  • 500 MB free hard disk space required to install
  • Internet Explorer 5.01 Service Pack 2 or later version
  • CD-ROM drive
  • SVGA monitor (800 x 600 pixels, 16-bit color)
Macintosh
  • Mac OS X 10.2.8, 10.3, 10.4
  • 233 MHz PowerPC processor
  • 64 MB RAM (Mac OS X: 128 MB RAM)
  • 240 MB available hard disk space
  • 800 x 600, 16-bit color SVGA monitor
  • CD-ROM drive
  • HP Memories Disc Creator software requires CD-Writer and 700 MB additional hard disk space
