HP Designjet 820 MFP - Product Specifications
Technical specifications
Print
Print Speed
90 sec D/A1 line drawings on HP Bright white Inkjet media, 85 ft2/hr (7.9 m2/hr) color image on HP Coated media in fast mode
Print Resolution Maximum
2400 x 1200 dpi (on HP Premium Photo Paper)
Technology
HP Color Thermal Inkjet
Technology resolution
HP Color Layering Technology
Print cartridge colors
Black, cyan, magenta, yellow
Ink types
Pigment-based black, dye-based color
Ink drop
18 pl (black ink), 4 pl (color inks)
Scan
Scan speed
Color (200 dpi): 1.5 in/sec (38 mm/sec), black & white (200 dpi): 5 in/sec (127 mm/sec)
Scan/Copy resolution
Best mode: color and black & white 300 x 300 dpi
Draft mode: color and black & white 200 x 200 dpi
Normal mode: color and black & white 200 x 200 dpi
Enhanced mode: 2400 x 2400 dpi with variable resolution settings from 50 dpi in increments of 1 dpi
Maximum scan width
42 in (1067 mm)
Maximum scan thickness
0.6 in (15 mm)
Copy
Reduction/Enlargement
1 to 10000%
Maximum copies
99 copies
Copier settings
Type of original, image crop and align preview, lightness, saturation and RGB controls, sharpen/blur, mirror copy, enlarge/reduce, paneling, tiling, nesting, accounting
Media handling
Printer
Single-sheet feed, roll feed, automatic cutter, standard bin
Scanner
Straight-through scan paper path for sheet and cardboard originals, servo assisted media thickness adjustment
Media types
Printer
Bright white inkjet paper (bond), translucent bond, natural tracing paper, vellum, clear film, matte film, coated paper, heavyweight coated paper, high-gloss photo paper, semi-gloss photo paper, paper-based semi-gloss, satin poster paper, studio canvas, banners with Tyvek, colorfast adhesive vinyl.
Scanner
Non-abrasive paper, vellum, mylar, sepia, blueprints, plastic film, plastic laminate, foam board, cardboard. (No plywood, stone plates, metal plates or abrasive, dirty, rough, sharp edged, metal clamped, burned surfaces, transparencies.)
Processing and memory
Printer
160 MB
Scanner
Pentium IV, 2.6 Ghz, 1 GB memory, 23 GB hard disk
Connectivity
Interfaces standard
Printer: Centronics parallel IEEE 1284-compliant (ECP), HP Jetdirect WIO 10/100 Internal Print Server
Scanner: Fast Ethernet 10/100 Base-TX
Drivers (included)
Printer: Microsoft Windows 95, 98, Me, NT 4.0, 2000, Macintosh OS 8.1 or later, AutoCAD 2000, R 13, R 14, for Windows.
Scanner: Microsoft Windows drivers for HP Designjet 500, 800, 1000, 4000, 4500, 5000 and 5500 series printers
Print languages: Adobe PostScript 3, HP-GL/2, HP-RTL, CALS G4
Dimensions (w x d x h)
MFP
80.1 x 40.9 x 63.0 in/2034 x 1040 x 1600 mm
Printer shipping
85.8 x 28.7 x 43.7 in/2180 x 730 x 1110 mm
Scanner shipping
74.8 x 26.7 x 61.6 in/1900 x 680 x 1565 mm
MFP
404.5 lb/183.47 kg
Printer shipping
216 lb/98 kg
Scanner shipping
370.3 lb/168 kg
What's in the box: HP Designjet 820 MFP including printer, scanner, touch screen, keyboard, built-in HP Jetdirect 620n network card, additional Fast Ethernet 10/100 Base-TX, printer and scanner stands, media bin, spindle, power cords, ink cartridges, printheads, roll of media, print/scan/copy software, HP Macroinstaller with Microsoft Windows drivers for HP Designjet 500, 800, 1000 and 5000 series printers, HP-GL/2, AutoCAD and PostScript drivers for Windows, PostScript driver for Macintosh, ZEHRaster Plus for UNIX, system recovery software CD, Quick Reference Guide, Setup Poster, user documentation CD (interface cables must be ordered separately)
Environmental ranges
Recommended operating temperature
64 to 90° F/ 18 to 32° C
Storage temperature
-4 to 131° F/ -20 to 55° C
Operating humidity range
20 to 80% RH
Recommended humidity range
25 to 75% RH
Acoustic
Sound pressure, active
46 dB(A)
Sound pressure, standby
42 dB(A)
Sound power, active
6.9 B(A)
Sound power, standby
5.8 B(A)
Power consumption
330 watts maximum
Power requirements
Printer
Input voltage 100 to 240 VAC (+/- 10%), auto range, 50/60 Hz, 8 amp maximum
Scanner
100 to 240 VAC (+/- 10%), auto range, 50/60 Hz, 5 amp maximum
Certification
Safety certification
Compliant with ITE requirements including EU LVD and EN60950, UL or CSA certified for US and Canada, and others.
Electromagnetic compatibility
Compliant with Class A ITE requirements including EU (EMC Directive), USA (FCCrules), Canada (DoC), Australia (ACA), New Zealand (MoC), Japan (VCCI)
Energy Star compliant
Yes (printer only)
One-year, next-business-day, on-site warranty
