HP Designjet 9000s Printer Series - Open Cover Replace Ink Message
If ink cartridge is not installed, or the printer is not recognizing a cartridge, the front panel displays the following message:
Figure : Message for left cover ink cartridges
XX = Ink color
  • K: Black
  • Lm: Light magenta
  • Lc: Light cyan
Figure : Message for right cover ink cartridges
XX = Ink color
  • C: Cyan
  • M: Magenta
  • Y: Yellow
Installing an ink cartridge
Always use genuine HP ink cartridges. These have been designed for high-quality imaging performance and reliable printer operation. Using non-HP inks may cause poor print quality, printer malfunction, or printer failure. The hazard characteristics of different solvent inks can vary widely. HP has not conducted product safety testing for non-HP inks with this printer and is not responsible for any loss or damage that may result if non-HP inks are used.
HP ink cartridges must be installed before the “Install By” date printed on the cartridge. Use of the ink cartridge 3 months beyond the “Install By” date may cause deterioration in print quality or a printer malfunction.
If an ink cartridge cannot be inserted, check that the color matches the slot. A mechanical key prevents an ink cartridge from being inserted into the wrong slot.
Do not shake ink cartridges before inserting into the printer.
Follow the steps given below to replace an empty ink cartridge:
  1. Open the ink cover in the direction of the arrow shown in the figure below.
    Figure : Opening the ink cover
  2. Remove an ink cartridge from the printer. Pull it in the direction of the arrow shown in the figure below.
    Figure : Removing an ink cartridge
  3. Insert a new ink cartridge into the printer.
    Figure : Inserting a new ink cartridge
  4. Close the ink cover.
