HP Officejet 6300 Series All-in-One - Receive a Fax
The HP All-in-One receives faxes automatically or manually. If the Auto Answer option is turned off, faxes must be received manually. If the Auto Answer option is turned on, the unit automatically answers incoming calls and receives faxes after the number of rings specified by the Rings to Answer setting. The Auto Answer option is the default option, and the default Rings to Answer setting is five rings.
To receive faxes manually, the unit must be connected to a telephone in one of two ways:
  • Directly connected to the unit on the 2-EXT port
  • On the same telephone line, but not directly connected to the unit
This document applies to the following products:
  • HP Officejet 6301, 6304, 6305, 6307, and 6308
  • HP Officejet 6310, 6310v, 6310xi, 6313, 6315, and 6318
Receive a fax
Receiving faxes automatically
If the Auto Answer option is set to On, the unit automatically answers incoming calls and receives faxes after the number of rings specified by the Rings to Answer setting.
  1. Press Auto Answer to turn on the Auto Answer option.
      Figure : Setting the Auto Answer option
    1. Auto Answer button
    The Auto Answer button is lit when the Auto Answer option is turned on.
  2. Press Auto Answer again to turn off the Auto Answer option.
Receiving faxes manually
If you turn off the Auto Answer option to receive faxes manually or you answer the phone and hear fax tones, use the following instructions to receive faxes manually.
  1. Verify that the unit is turned on and that there is paper loaded in the input tray.
  2. Remove any originals from the document feeder tray.
  3. If the Auto Answer button is lit, press Auto Answer to turn off the Auto Answer option.
  4. If you are currently on the phone with the sender, instruct the sender to press Start on their fax machine.
  5. When you hear fax tones from a sending fax machine, do the following:
    1. Press Start Fax Black or Start Fax Color.
    2. When prompted, press 2 to select Fax Receive.
      If you cannot reach the control panel, wait several seconds and then press 1, 2, and 3 on the telephone. If the unit does not start receiving the fax, wait several more seconds and then press 1, 2, and 3 again.
    3. After the unit starts receiving the fax, you can hang up the phone or remain on the telephone line. The telephone line is silent during fax transmission.
Country: Flag Serbia
