HP Designjet 9000s Printer Series - Loading Roll Media
Do not touch heater surfaces in the paper path. This may cause burns.
Handle media rolls with care. They can be heavy and difficult to move in confined spaces. In some cases, two people should move and install media rolls. Dropping a media roll could cause personal injury or damage to the printer.
The printer's front panel messages will guide you through the process of loading media. To install a media roll:
  1. Open the rear cover and slide the media edge guards to each end of the platen.
    Slide the fan guide lever to the right side of the platen to avoid obstructing the media path and damaging the media.
      Figure : Setting the media edge guards
    1. Media edge gaurds
    Position the media edge guards after loading the media. Position the fan guide lever after loading the media.
  2. Close the rear cover.
  3. Loosen the lock on the left media hub by turning the lock anti-clockwise.
      Figure : Left media hub lock
    1. Sliding media hub
    2. Media hub lock
  4. Adjust the position of the left media hub to allow for insertion of the roll of media.
  5. You can feed the media through the media path over (externally) or under (internally) the roll according to the side of the media you want to print on. Make sure you insert the end of the roll that will allow you to print on the correct side.
      Figure : External and internal winding
    1. External (clockwise) winding
    2. Internal (anti-clockwise) winding
  6. Insert the roll of media into the right media stop (fixed side).
      Figure : Insert the roll of media
    1. Media stop
    2. Roll
  7. Slide the left media hub (movable side) into the core of the media roll.
      Figure : Removing the media stop
    1. Media roll
    2. Media hub lock
    3. Sliding media hub
  8. Tighten the left media hub lock by turning clockwise.
  9. Lift the media load lever.
    Figure : Lift the media load lever
  10. Ensure the Media End (ME) lever is in the forward position.
    Figure : Pull the Media End lever forward
  11. Feed the media until a beep sounds from the media feeder (about 200 mm).
    Figure : Feeding the media
    If you have problems loading media, feed the media into the printer by holding both edges of the media.
    Take care that the media does not curl inside the rear cover and that the media edge guards are not obstructing the media path.
    The vertical media line guide on the printer is for sheet media loading only. Do not use for roll media.
  12. Take up any excess media by rewinding the media stop on the media roll. This will help to make sure there is even tension across the width of the media and avoid skew.
      Figure : Rewind excess media onto the roll
    1. Rewind excess media onto the roll.
  13. Lower the media load lever.
    Figure : Lowering media load lever
  14. Open the rear cover and adjust the media edge guards and adjust the position of the fan guard lever.
      Figure : Adjusting the fan guard lever
    1. Fan guard lever
    2. Media edge guard
    To complete the loading procedure, follow the front panel instructions.
  15. Confirm the position of the media edge guard and press the OK key.
  16. Select media roll.
    1. Select ROLL using the Up or Down arrow keys.
    2. Press the OK key to confirm the selection.
  17. Select a media type.
    1. Select the media type using the Up and Down arrow keys.
      There are five preset media types to choose from:
      • Paper
      • Glossy
      • Matte
      • Banner
      • BLT_B (Backlit)
    2. Press the OK key to confirm.
      If you wish to select a media type that is currently not available, then you will need to create a new media type.
    3. Select the NEW MEDIA ENTRY option using the UP or Down arrow keys, and press OK.
      Press the CANCEL key to return to the SELECT MEDIA menu.
  18. The media will be loaded automatically.
