HP Designjet 4500 Stacker - Changing the Temperature
Changing the Stacker temperature
The stacker contains a heated roller to remove the curl from the paper. To change the temperature of the roller, select the (roll) icon on the printer's front panel, then Accessories , Stacker, Select temperature level.
There are three options:
  • Normal: It is the default and recommended setting.
  • High: It sets the roller to a higher temperature, which may be useful for particularly stiff paper.
  • Low: It sets the roller to a lower temperature, which may be useful for paper with a particularly sensitive coating.
Country: Flag Serbia
