    Windows 11 Upgrade Guide
HP L1906 Flat Panel Monitor - Overview
Product Description
The HP Flat Panel Monitor L1906 is ideal as a large-screen CRT replacement for corporate customers, growing businesses, and the government sector.
Product Features
Feature
Specification
Features
Type
Thin-Film Transistor (TFT)
Size / Viewable Image Size (diagonal)
19.0 in (48.25 cm) maximum viewable
Native Resolution
1280 x 1024 @ 60 Hz
Signal Input
Attached 15-pin D-sub (analog VGA)
Horizontal Viewing Angle
140 degrees
Vertical Viewing Angle
130 degrees
Cabinet Colors
Carbon/Silver
Image Quality
Brightness (typical)
Up to 250 nits (cd/m2)
Contrast Ratio (typical)
up to 500:1 (typical)
Pixel Pitch
0.294 mm
Horizontal Frequency Range
30 to 83kHz
Vertical Frequency Range
56 to 76 Hz
Ease of Use Feature
User Programmable Modes
10
Plug and Play
Yes
On-Screen Controls
Image Control (auto, horizontal, vertical), Positioning (vertical and horizontal), Color Temperature (6500k, 9300k, Custom), Brightness, Contrast, Clock, Clock Phase, Monitor Management (power saver, sleep), Factory Reset
Language Selection
Yes
Asset Control
Yes
Resolution
1280 x 1024
60 Hz and 75 Hz
1024 x 768
60 Hz, 70 Hz, and 75 Hz
800 x 600
60 Hz, 72 Hz, and 75 Hz
720 x 400
70 Hz
640 x 480
Ergonomic Features
Anti-Glare/Anti-Static
Yes/Yes
Tilt/Swivel
Yes/No
Tilt Angle
-5 degrees to +30 degrees
Approvals / Certifications
MPR-II Compliant
Yes
ISO 9241-3,7,8 VDT guidelines, ISO 13406-2 pixel defect guidelines
Yes
Energy Star Compliant
Yes
FCC Approval
Yes
TCO '99 Certified
Yes
UL Approval
Yes
Hardware Features
Sync Input
TTL separate synch
Dimensions without stand (HxWxD)
42.7 x 42.2 x 20.3 cm (16.8 x 16.6 x 8.0 in)
Weight unpacked
36.2 x 42.2 x 5.9 cm (14.3 x 16.6 x 2.3 in)
Weight packaged
5.3 kg (11.7 lb)
Accessories
7.0 kg (15.4 lb)
Service and Support
3/3/3 including backlight (Parts/Labor/On-Site)
Software Overview
HP Display LiteSaver
HP Display LiteSaver feature allows you to schedule Sleep mode at preset times to help protect the monitor against image retention, drastically lower power consumption and energy costs, and extend the lifespan of the monitor.
Link to Product Specifications
