    Looking for Site Help?
HP Notebook PCs - "162 - System Options Not Set" Error Message Appears On Black Screen
HP recommends the following resolutions for Sorry for the inconvenience, but Windows Failed to Start Successfully error messages referring to 162 - System Options not set that may occur before Windows XP or Windows 2000 is started.
This error message occurs when the hardware is modified and the System BIOS options are forced to change.
Step 1: Reset the default BIOS
Use the following steps to reset the default BIOS settings.
  1. Press and hold the Power button for 5 Seconds to turn off the PC.
  2. Press and hold the F10 key while you press the Power button to turn on the PC. Release the F10 key after text is displayed on the screen of the PC.
  3. After the BIOS Setup Utility is displayed, press the F9 key to select Setup Defaults.
  4. Press the F10 key to select Save and Exit.
Step 2: Schedule a repair
If the preceeding method does not resolve the error, please contact HP to schedule a repair.
Country: Flag Serbia
