HP Color LaserJet 4700 Printer Series - Paper Handling Menu Overview
Overview
The printer driver or software application can perform most routing tasks from the printer driver or a software application. This is the most convenient way to control the printer, and will override the printer control panel settings.
The printer control panel also changes settings and allows access to printer features that are not supported by the printer driver or a software application.
If other HP LaserJet printer models were used, the user might be accustomed to configuring Tray 1 to First mode or Cassette mode. On HP Color LaserJet 4700 series printers, setting Tray 1 size and type to ANY SIZE is equivalent to First mode. Setting size or type for Tray 1 to a setting other than ANY SIZE is equivalent to Cassette mode.
How to access menus
  1. Press MENU to enter MENUS.
  2. Press the up arrow button or down arrow button to navigate the listings.
  3. Press the checkmark button to select the appropriate option.
Paper-handling menu options
The paper handling menu allows the user to configure input trays by size and type. It is important to correctly configure the trays with this menu before printing for the first time.
Paper handling menu options
Menu item
Value
TRAY 1 SIZE
A list of available sizes appears.
Allows the user to configure the media size for Tray 1. The default is ANY SIZE.
TRAY 1 TYPE
A list of available media types appears.
Allows the user to configure the media type for Tray 1. The default is ANY TYPE.
TRAY <N> SIZE
N = 2, 3, 4, 5, or 6
Allows the user to configure the media size for Trays 2, 3, 4, 5, or 6. The default is Letter. The media size is detected by the guides in the tray.
TRAY <N> TYPE
Allows the user to configure the media type for Trays 2, 3, 4, 5, or 6. The default is PLAIN.
Country: Flag Serbia
