HP Compaq t5700 Thin Client - Epson TM-88III Printer cannot be Installed under XPembedded SP1/2
Issue:
The installation of the Epson printer aborts with error message:
Cause : the specified module could not be found.
Code : 0x030200005
The Epson driver requires the presence of System Restore which is not included in the XPe images to keep the OS footprint as small as possible.
Solution
It is possible to install the System Restore from the Windows XP media by following these steps.
  1. Reload thin-client image using SP29705.EXE.
  2. Login as Administrator; and hold Shift key and keep it down while logging out (Start, Log off, Log Off)
    Use Administrator as username and password. It is case sensitive.
  3. Disable write filter and reboot unit to commit.
  4. Login as Administrator and map a drive letter to a share containing Windows XP SP2 installation files.
    For example: NET USE P: \\SERVER\SHARENAME\
    Alternatively use a USB cd-rom.
  5. Expand sr.in_ from P:\i386 directory
    expand p:\i386\sr.in_ c:\sr.inf
    Browse to the P:\i386 directory when asked for additional files.
  6. Right click c:\sr.inf , and select install to install the System Restore.
  7. Reboot when asked.
    Before rebooting, it is perfectly safe to disconnect the share.
  8. Login as Administrator and launch the printer driver executable, ATM_301aE.exe, OS: Windows XP, Language: US.
    Select USB Driver and EPSON TM-T88III Receipt; and press Printer Port Settings for the printer.
  9. Set as default printer, and choose USB and OK.
  10. Finish and restart when asked.
  11. Login as Administrator.
  12. Connect and power on the printer. It will be detected automatically.
  13. Print a test page to verify functionality.
  14. Enable write filter and reboot to commit.
