    Fix HP Printer issue on macOS
HP Compaq t5520 Thin Client Specifications
Product description
The HP Compaq t5520 Thin Client with Microsoft Windows CE 5.0 delivers a great desktop experience for task-oriented workers using general office applications or your specific line of business software. This reliable client takes you to the next level of thin client computing with expanded options and preloaded software to help you do more.
Product features
Feature
Processor
VIA Eden 800 MHz
Memory
64 MB Flash with 128 MB DDR SDRAM
16 MB of system RAM is reserved for video graphics usage
Graphics
VIA S3 graphics with support for high-resolution monitors up to 1280 x 1024
Input/Output/Peripheral Support
  • Keyboard
    USB (keyboard included), PS/2
  • Mouse
    USB (mouse included), PS/2
  • Printer
    Local and/or network printers (RDP, ICA, LPD, JetCET)
  • Video
    VGA-type video output (DB-15)
Audio
  • Output
    Internal amplified speaker, 1/8-inch mini, full 16-bit stereo, 44-kHz sample rate
  • Input
    1/8-inch mini microphone
Ports
4 USB, 1 Serial, 1 Parallel, 1 PS/2
Security
Security lock slot (cable lock sold separately)
Terminal server protocols
Integrated Microsoft RDP 5.5 for Windows CE 5.0 and Citrix ICA 8.2 for remote server access.
Networking
  • TCP/IP with Dynamic DNS and DHCP support
  • 10/100 BaseT Fast Ethernet, twisted pair (RJ-45)
  • Direct Connection through Point-to-Point Protocol (PPP), Point-to-Point over Ethernet (PPPoE)
  • VPN Connection through MS Point-to-Point Tunneling Protocol (PPTP), Layer-2 Tunneling Protocol (L2TP)
  • Supports Citrix load balancing on ICA
  • Simple Network Management Protocol (SNMP)
  • Server Network Time Protocol (SNTP)
  • DHCP with FTP option for automatic updates
  • Wake on LAN
  • PXE
Dimensions (H x W x D)
  • 55 x 205 x 195 mm (2.2 x 8.2 x 7.8 in) without stand
  • 230 x 100 x 195 mm (9.2 x 4 x 7.8 in) with stand
1.41 kg (3.1 lb)
Environmental
  • Temperature range on
    0o to 40o C (32o to 104o F)
  • Temperature range off
    -40o to 60o C (-40o to 140o F)
  • Humidity
    20% to 80% condensing/10% to 95% non-condensing
  • Power
    Worldwide auto-sensing 100-240 VAC, 50-60 Hz energy-saving automatic power-down
Compliance
  • Ergonomics
    German ZH1/618; EN29241-3, approved
  • Safety
    UL 1950, CSA 950; TÜV-GS (EN60 950) approved
  • RF Interference
    FCC Class B; CE Mark; EN55022B; VCCI
Physical specifications
Feature
1.41 kg (3.1 lb)
Software/OS
Feature
Server OS compatibility/support
Microsoft Windows NT Server 5.5 family, Microsoft Windows 2003 Server family, Microsoft Windows 2000 Server family (except Data Center addition); Citrix Metaframe XP, and Citrix Presentation Server 3.0 for Windows 2000/2003 Servers/Linux/Unix
  • Microsoft Windows CE 5.0
  • Microsoft Internet Explorer 6.0 for Windows CE 5.0
  • Microsoft Windows Media Player 9.0 for Windows CE 5.0
  • Altiris Deployment Solution (client agent), Altiris Deployment Solution (management console) available as free download from Altiris.
  • JetCET Print Professional
  • teemtalkCE Terminal Emulation Software
  • VNC Server
  • txtpad
  • Other software available as add-ons
Browser
Management
Altiris Deployment Solution (client agent) preinstalled.
Environmental specifications
Feature
Environmental
  • Humidity
  • Power
Certifications
Feature
Compliance
  • Ergonomics
  • Safety
  • RF Interference
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
