HP iPAQ rz1700 series Pocket PC - Maintaining the Battery
Overview
The following can maximize battery life:
  1. Leave your HP iPAQ connected to AC power at all times when not using it.
  2. Set the device to turn off after a short time of not being used.  Tap Start > Settings > System tab > Power > Advanced tab.  On battery power, set the device to power off in the shortest acceptable time.
  3. Dim the backlight. Tap Start > Settings > System tab > Backlight > Brightness tab. Adjust the battery brightness level slider to dim the backlight.
  4. Turn off the backlight. Tap Start > Settings > System tab > Backlight > Battery Power tab; then set the backlight to turn off soon after you stop using the device.
  5. Set the device to receive incoming infrared beams manually.  Tap Start > Settings > Connections tab > Beam ; then uncheck Receive all incoming beams .
  6. Assign a program button to turn off the screen display while listening to music. Open Windows Media and tap Tools > Settings > Buttons . From the Select Function dropdown list, tap Screen Toggle . Press a program button and tap OK .  Then, when listening to music, press that program button to turn off the screen display.
Country: Flag Serbia
