Compaq Evo n800w Notebook PC - Overview
Delivers true workstation graphics, features, and performance.
Features
 845MP chipset
BIOS
Compaq BIOS
Processor
  • 2.0 GHz on Mobile Intel Pentium 4 processor-M with 512 KB L2 cache
  • 2.2 GHz on Mobile Intel Pentium 4 processor-M with 512 KB L2 cache
Cache
512KB
Memory
  • Standard: 256 MB (266 MHz) DDR SDRAM (256 MB SODIMM in slot 1)
  • Maximum: 2 GB (266 MHz) DDR SDRAM (1024 MB SODIMMs in slots 1 and 2)
Storage
Hard Drive:
  • 60-GB 5400 RPM
  • 40-GB 5400 RPM
  • 30-GB 4200 RPM
Optical Drive
  • DVD-CD-RW
  • DVD-ROM
  • CD-ROM
Video
ATI Mobility Fire GL 9000 Graphics, 64-bit video, 4X AGP with 64-MB DDR video memory
  • 15-inch color TFT UXGA with 1600 x 1200 resolution (up to 16.7M colors internal)
  • 15-inch color TFT SXGA+ with 1400 x 1050 resolution (up to 16.7M colors internal)
Audio
Dual Integrated JBL Pro Speakers 16 bit stereo sound Headphone and Microphone Jacks
Communications
  • 10/100 NIC is integrated on the system board (LOM)
  • Type III Mini PCI 56K (V.92) modem
Power
External 65-watt AC adapter, 6-foot/1.8-meter power cord included
Battery
Lithium-Ion Battery Pack (8-cell)
Pointing Device
Dual pointing devices (both pointstick and touchpad)
Ports \ Slots
  • MultiPort
  • PC Card One Type II
  • Enhanced Parallel EPP/ECP
  • S-Video
  • VGA
  • Port Replicator
  • Headphone/Line-out
  • Microphone in
  • DC Power
  • RJ-11 (modem)
  • RJ-45 (NIC)
  • Infrared Port
  • Two USB Port (USB 2.0)
  • LED status indicators
Security
  • Configuration Control Hardware
  • Memory Change Alert
  • Ownership Tag
  • Set-up Password
  • Power-On Password
  • DriveLock
  • Enabled for PC SmartCard options
  • Kensington Lock
Operating System
Windows 2000 or Windows XP Pro Depending on Model
Dimensions (HxWxD)
1.4 x 12.9 x 10.5 in (3.6 x 32.8 x 26.7 cm)
  • 15-inch LCD, weight saver, 1 SODIMM 6.0 lb (2.72 kg)
  • 15-inch LCD, CD-RW, DVD or CD-ROM, 1 SODIMM 6.6 lb (2.98 kg)
Certifications
CAD Autodesk AutoCAD
Autodesk Inventor
Dassault Solidworks
EDS/PLM Unigraphics
PTC Pro/Engineer
Dassault Catia
Bentley Microstation
DCC Avid Express DV 3.5
Pinnacle Edition
Adobe Premiere/After Effects
Discreet 3DS MAX/Combustion
Alias|Wavefront Maya
Avid SoftImage XSI/3D
CAD ICEM Surf
DCC Side Effects Houdini, Houdini Select
FEA MSC.Patran
3-3-0 worldwide limited warranty
