Evo Notebook N1020v - Installing an RTC Battery
Installing RTC Battery
Removing the RTC Battery
  1. Prepare the computer for disassembly.
  2. Remove the mini PCI compartment cover.
  3. Remove the RTC battery from its socket on the system board.
NOTE: Battery
The computer uses a CR1220 lithium disk cell battery. When replacing the RTC battery, insert the battery with the “+” sign facing up.
Installing the RTC Battery
Reverse the preceding procedures to install a RTC Battery.
