    We are upgrading our website
Evo Notebook N1020v - Installing an Heat Spreader
Installing Heat Spreader
Removing the Heat Spreader
  1. Prepare the computer for disassembly.
  2. Remove the LED cover.
  3. Remove the keyboard.
  4. Disconnect the fan cable 1 from the system board.
  5. Remove the following screws:
    • One TM2.5 x 5.0 screw 2 next to the fan
    • One TM2.5 x 5.0 screw 3 that secures the display video cable ground loop
    • Four spring-loaded TM2.5 x 14.0 shoulder screws 4
    • One TM2.5 x 8.0 screw 5 next to the keyboard and TouchPad ZIF connectors
    NOTE: Removal Sequence
    The four spring-loaded shoulder screws should be removed and installed in the 1, 2, 3, 4 sequence stamped on the heat spreader adjacent to each screw hole.
  6. Remove the display video cable 1 from the routing channel in the heat spreader.
  7. Lift the right side of the heat spreader until it rests at an angle 2.
  8. Slide the heat spreader to the right at an angle 3 and remove the heat spreader from the base enclosure.
Installing the Heat Spreader
Reverse the preceding procedures to install a Heat Spreader.
