HP Compaq nc8000 and nw8000 notebooks - Installing the Display
Overview
  1. Remove the keyboard.
  2. Disconnect the wireless antenna cables from the Mini PCI wireless communications board.
  3. Remyove the LED switch cover.
  4. Disconnect the display cable (1) from the system board.
  5. Remove the wireless antenna cables from the opening (2) and the clips (3) in the top cover.
  6. Position the notebook with the rear panel facing toward you.
  7. Remove the two screws (1) that secure the display hinge covers to the notebook.
  8. Remove the two screws (2) that secure the display assembly to the notebook.
  9. Lift the display assembly straight up (1) to remove it from the notebook.
  10. If necessary, remove the display hinge covers (2) from the display assembly.
  11. Reverse the above procedure to install the new display assembly.
