Compaq Tablet PC TC1000 - WLAN MiniPCI Card Specifications
Physical Specifications
Dimensions (L x W x H)
59.6mm x 50.8mm x 4.8mm
14.2 gram
Temperature and Humidity (non condensing)
Operation
10 to 49 C Maximum humidity 90%
Transit (shipping)
-30 to 70 C Humidity 5 to 90%
Storage
-20 to 60 C Humidity 5 to 90%
Power Characteristics
Standby mode
68 mA
Receive mode
270 mA (Nominal)
Transmit mode
550 mA (Nominal)
Power supply
3.3 V
Networking Characteristics
Compatibility
  • IEEE 802.11 Standard for Wireless LANs (DSSS)
  • Wi-Fi (Wireless Fidelity) certified by the Wireless Ethernet Compatibility Alliance (WECA)
  • Mini PCI specification
Host operating system
Microsoft Windows XP Tablet Edition
Media Access Protocol
CSMA/CA (Collision Avoidance) with Acknowledgement (ACK)
Radio Characteristics
R-F frequency band
2.4 GHz (2400-2500 MHz)
Sub-channels
  • 1 - 2412
  • 2 - 2417
  • 3 - 2422
  • 4 - 2427
  • 5 - 2432
  • 6 - 2437
  • 7 - 2442
  • 8 - 2447
  • 9 - 2452
  • 10 - 2457
  • 11 - 2462
  • 12 - 2467 (ETSI approved countries and Japan only)
  • 13 - 2472 (ETSI approved countries and Japan only)
  • 14 - 2484 (Japan only)
Spreading
11-chip Barker Sequence, DQPSK, DBPSK and CCK
Bit Error Rate (BER)
Better than 8%
Nominal output power
16 dBm
Encryption
128-bit (RC4), also supports 64-bit RC4/WEP (Wired Equivalent Privacy)
Regulatory Information
Wireless communication is often subject to local radio regulations. Although wireless networking products have been designed for operation in the license-free 2.4 GHz band, local radio regulations may impose a number of limitations to the use of wireless communication equipment.
The range of the wireless signal is related to the Transmit Rate of the wireless communication. Communications at lower Transmit Rates will travel larger distances.
  • The range of your wireless devices can be affected when the antennas are placed near metal surfaces and solid high-density materials.
  • Range is also impacted due to obstacles in the signal path of the radio that may either absorb or reflect the radio signal.
