Evo Notebook N800w - Installing the Processor
Installing Processor
CAUTION: Before removing the processor, make special note of the orientation of the printing on the processor. The gold triangle should be in the lower right corner when installing the processor. The processor must be installed in the same orientation in which it was removed.
  1. Prepare the computer for disassembly (Section 5.3) and remove the following components:
    1. LED cover
    2. Keyboard and shield
    3. Display
    4. Top cover
    5. Fan
  2. Use a flat-bladed tool to turn the processor locking screw 1 one-half turn counterclockwise.
  3. Lift the processor straight up and remove it 2.
NOTE: Orientation
Make sure the gold triangle 3 is in the lower right corner when installing the processor.
Replacing the Processor
Reverse the above procedure to install the processor.
